Wheel / tire size and Gas Mileage / speedometer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2006, 01:30 PM   #1 (permalink)
Matt "Mr. Wizard" Price
View Wizrd23's Photo Gallery
Talking Wheel / tire size and Gas Mileage / speedometer
Just a quick question Ladies and Gents,
I have an 07 Camry LE I4, with the stock 16 wheels and tires. I am going to get new wheels and tires, and was wondering how big I should go, and how much it effects gas mileage and the effect has on the accuracy of the speedometer?
I realize as the wheels get larger, you get fewer rpms, so it is going o effect the ride and speedometer a little.
And I know you can get wheels as large as 20" on the Camry, but I don't want to go that big if its going to kill the gas mileage and mess up the ride.
I'm also considering the Springtech lowering springs for the car, to drop it about 1.5" to get rid of wheel gap. This is a daily driver and I baby it everywhere I go.
thanks!
Wizrd23 is offline   Reply With Quote
Old 06-17-2006, 02:50 PM   #2 (permalink)
View southpawz's Photo Gallery
Go here: http://www.miata.net/garage/tirecalc.html
You put in your current tire/wheel size and then you can play with the new tire/wheel size until you find something that gets everything back to where it needs to be.....it also will show how much your speeometer will be off with different sizes.
HTH
southpawz is offline   Reply With Quote
Old 06-17-2006, 03:51 PM   #3 (permalink)
Thanks southpawz! That helped alot. I was using bigwheels.net to look at possible wheels (one of the few sites that lists the 2007 Camry and has a huge selection). anyway, amazingly you can get all the way up to 20" wheels with 225/35/YR20 tires and it makes next to no difference!
now the question is, do I want to go with 20" wheels and lo-profile tires, or 18" wheels and tires and then drop it 1.5"? Or can I drop the car on 20"? I don't want rub obviously, but I also want to be able to go to the grocery store and go over a speed bump without bottoming out. Thoughts?
Old 06-17-2006, 05:10 PM   #4 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
Please get the 18s, you will have a huge drop in performance with 20s. That is a ton of extra weight. Plus, if you lower it, it will look better anyway. With 20s your lowering options are very limited.
Blackhawk3D is offline   Reply With Quote
Old 06-17-2006, 07:12 PM   #5 (permalink)
rusty9's Avatar
Gameroom cash: $441505
View rusty9's Photo Gallery
^^ yeah, you will appreciate actually having sidewalls with the 18's instead of a rubberband 35 series tire on 20 inch rimzzzz...
rusty9 is offline   Reply With Quote
Old 06-17-2006, 08:09 PM   #6 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
HTH
Good one SouthPawz!
Newbie knows a lot. Miata.net is the place to go. They used to have 2 versions, one old and one new.
This is how the old one looks like
skewe is offline   Reply With Quote
Old 06-17-2006, 10:04 PM   #7 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
I think 17" or 18" are best for the Camry, unless you are pimping large, the the chosen few go with the 19" and 20"s...
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 07-23-2006, 05:49 PM   #8 (permalink)
View St. Dogmael's Photo Gallery
Hey Wizrd,
I was wondering if you put in the 18"s, and if so, how they affected your ride? I'm getting a CE (only trim level I could find in manual tranny) and am thinkng about going to 17" or even 18".
Thanks,
Dogmael
St. Dogmael is offline   Reply With Quote
Old 07-23-2006, 07:06 PM   #9 (permalink)
Streaker
Gameroom cash: $121159
View Streaker's Photo Gallery
Potholes must be killers if you have 19 or 20" wheels. I have 17" rims now and worry about my wheels being dented or damaging a tire in the City
Streaker is offline   Reply With Quote
Old 11-16-2006, 08:34 PM   #10 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Question
I would think that potholes would be less of a problem with large diameter wheels.
What am I missing here?
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 11-16-2006, 08:53 PM   #11 (permalink)
View trickyazn's Photo Gallery
with bigger rims the tire profile will be smaller which means when you go over the pothole, the rim will take some of the impact depending on how fast you go over it. bigger the rim, smaller the profile, rim > tire in terms of impact.
trickyazn is offline   Reply With Quote
Old 11-23-2006, 10:16 PM   #12 (permalink)
Digger1's Avatar
Exclamation
Trick,
Got it, wasn't considering the low profile tires.
Thnx!
Digger1
Gas Tank Size jays4x4 1st Generation (1995.5–2004) 5 05-31-2006 06:38 PM
Difference in gas mileage between LE and XLE (4 cylinder) kthan Camry & Solara Lounge 15 08-30-2005 08:11 PM
