I think this is ignition advance versus engine RPM. Advance is predicated on engine RPM. The higher the RPM, the more advance needed. Ignition and flame propagation do not happen instantaneously, or at least not under normal conditions. Conventional ignition systems also have this much advance.
I would not adjust valve train timing! One belt cog tooth would be way too much. There are automatic adjustable cam sprockets used on say V-8’s for hot rods that will adjust valve train timing. I am not sure how many degrees this setup allowed the cam timing to vary.
