Help, Timing Is Off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2006, 09:16 PM   #1 (permalink)
View tousi's Photo Gallery
Help, Timing Is Off
Can somebody direct me to a very good site with pixs that tells you how to time a 92 camry 4cyl timing belt? i tred to do the timing belt my self but come to find out it had no marks so it is off really bad. And does anyoen know if an off timing belt could cost gasoline to leak into the engine and smoke on startup? lmk thanxs
tousi is offline   Reply With Quote
Old 06-17-2006, 09:32 PM   #2 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
If your timing belt is off, I wouldn't drive the car, as the valves could possibly hit the piston, aka interference engine, which=dead.
Blackhawk3D is offline   Reply With Quote
Old 06-17-2006, 10:11 PM   #3 (permalink)
the 4cyl 5sfe is a non interference engine, someone corect me if i'm wrong.
Old 06-17-2006, 11:28 PM   #4 (permalink)
View toyomoho's Photo Gallery
Everything I read states the 5SFE is NON-interferance.
On the 95 5SFE engine there is no mark. It is a hole in the cam pulley that aligns with a mark on the camshaft bearing cover. Setting the correct cam/crank timing is not that difficult. It may take a few attempts to get it just right as things move a little when the belt slack is taken up by the idler pulley.
Perhaps your library has a Haynes, Chilton or Motor book. Check their referance department.
Old 06-18-2006, 02:20 AM   #5 (permalink)
View marc780's Photo Gallery
I hope these images from the shop manuals help. You can download the Toyota shop manuals from the stickies, in this forum.
Old 06-18-2006, 02:06 PM   #6 (permalink)
Gameroom cash: $304355
You are correct. It is a non-interference engine.
Mike
Old 06-18-2006, 02:24 PM   #7 (permalink)
Okay my bad. I have seen motors where the belt slipped and caused the motor to eat itself, it's not pretty.
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing questions tracyf Camry & Solara Lounge 11 03-23-2006 10:28 PM
91 replaced Water pump& timing belt 3sfe timings off now??? Toyotasrgreat! 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-24-2005 12:59 PM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
