How to clean engine bay? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2006, 11:30 AM   #1 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
I would like to clean my engine bay? What should I use? How have you guys done it? Degreaser and a toothbrush?
Blackhawk3D is offline   Reply With Quote
Old 06-18-2006, 11:43 AM   #2 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
I just use a clean cloth and brush, no solvents. I'm not sure how dirty your engine bay is.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 06-18-2006, 12:04 PM   #3 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
yeah depending on how bad it is, you may want to use some simple green and let that sit for a minute... then hose it off. youve gotta remember to cover the things that cant get wet though- i did it yesterday and covered the distributor cap, air filter, alternator and battery.
try a search, there is a lot of info on this subject
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 06-18-2006, 01:24 PM   #4 (permalink)
View mrlevis's Photo Gallery
I used this on my 95 Impala SS. This works really good. I never had a problem with it collecting dust either. I have used simple green on the stubborn areas
1) On a hot/warm engine, spray the entire engine compartment down with Windex. Close the hood and wait @ 3-5 minutes.
2) Lift the hood and mist the engine compartment with water. Now spray the entire area with Armor All. Close the cowl and again wait 3-5 minutes.
3) Repeat the Windex and Armor All application again. Now, after the second coat of Armor All, close up the engine compartment and wash and detail the exterior of your car.
4)When you are finished, open the hood and wipe down any excess Armor All.
mrlevis is offline   Reply With Quote
Old 06-18-2006, 01:34 PM   #5 (permalink)
93 240sx SR Hatch
DAMON's Avatar
^ i wouldnt spray a hot engine with a cold water
Old 06-18-2006, 02:11 PM   #6 (permalink)
.::{ XwORLD }::.
View Obelix's Photo Gallery
yep ! you only wash a cold engine...
Gen4|Mobil 1|Michelin|K&N|93 Octane|V6|Silverstar|KYB GR-2|
Obelix is offline   Reply With Quote
Old 06-18-2006, 02:44 PM   #7 (permalink)
93 240sx SR Hatch
DAMON's Avatar
unless you liked cracked blocks and headers, then by all means go for it!
Old 06-18-2006, 02:50 PM   #8 (permalink)
You are misting the engine...not soaking it with cold water. This is how detailers get your engine clean.
Old 06-18-2006, 04:05 PM   #9 (permalink)
Hawkeye-SE's Avatar
View Hawkeye-SE's Photo Gallery
No... no, its not.
Windex is NO WHERE near any detailers kit. Not on any surface, EVER.
Want a deep engine detail? Here is my method.
1) Engine should be warm (not hot) to the touch.
2) Remove all dry debris like leaves and shit by hand.
3) Cover coil packs, MAF, air filter, sensors, ect... with saran wrap or ziplocks. Secure with rubber bands. Aluminum foil works really well here too.
4) Spray the engine comptarment with light stream of water, you don't need to blast.
5) Apply degreaser. 303 aerospace cleaner or another citrus based cleaner is best. Simple green can stain rubber and corrode aluminum... don't use it. Work from the bottom of the engine compartment up.
6) Brush if necessary.
7) Hose the shit off.
8) Start the car and let it run for a few minutes.... finish drying with a towel.
9) Use a quick detailer on all the paint.
10) Then detail the rubber, vinyl, plastic, ect with a protectant like 303 aerospace protectant.
11) Give everything a final wipe down.
DONE.
Fyi - do above at your own risk... I am not responsible if you fuck your car up.
Hawkeye-SE is offline   Reply With Quote
Old 06-18-2006, 09:14 PM   #10 (permalink)
2002 Camry
I would wipe the engine (while warm) with a rag first before any chemicals/water is applied. Always remove as much excess as possible by clean cloth (no degreaser, etc). Then I would apply a degreaser if absolutely necessary ON the rag to clean the remaining, never mist or spray anything to the engine bay. Mist may overspray and contact with rubber/plastic parts which will deteriorate the plastic. But then again, this is me, being super picky.
If you engine bay is not very dirty, dont bother with any degreaser, etc.. Just use a rag and brush to clean. I always done this since day one to keep the engine bay clean and it's sparkling.
Old 06-18-2006, 09:25 PM   #11 (permalink)
View Klutch's Photo Gallery
I just pop the hood while I'm washing and give it a quick blast on the rinse. Generally the car wash uses hot water during the rinse. I never cover anything just don't soak the hell out of it and don't do it very often.
Engine bay always looks new and It's never messed with anything....
Klutch is offline   Reply With Quote
Old 07-15-2010, 08:31 AM   #12 (permalink)
Unofficial TN Member
Darchrow Enigma's Avatar
Gameroom cash: $154200
View Darchrow Enigma's Photo Gallery
why do i need to mess with the xterior paint if i'm degreasing the interior engine bay?
FS:
  • 255/40/R18 Turanza ER33 Tires ($60 shipped)
  • Lowering Springs: Eibach (Rear only) $80+shipping
  • Lexus IS250 18.5 Silver Rims non staggered($450 + shipping)
Darchrow Enigma is offline   Reply With Quote
gasoline smell in engine bay Redline Camry & Solara Lounge 4 03-29-2006 01:05 PM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 04:09 PM
Engine bay cleaning wildfire Camry & Solara Lounge 20 02-21-2005 01:11 AM
Increasing Horsepower in an AE92 azpriz90 Archived Corolla threads 5 01-11-2005 07:47 PM
