The second gen has a IIA(integrated ignition assembly). To get the RPM reading, you put that wire in the IIA testing port. I ran my positive wire to my ignition fuse, which is in the fuse box on the drivers front side. This way, whenever I insert my key the tach lights up and resets itself to 0 RPM. Also, if the key is not in, it will not receive power and thus not drain your battery. I took the negative wire and ran it behind a bolt and then tightened the bolt down to ground it. It's a pretty straightforward installation, and the only wire you have to run through the firewall is the one to the IIA testing port.
Sorry for the poor quality pictures, I can not find my nice digital camera.
The first picture gives you an idea of where the IIA testing port is located.
The second is just a close up of it.
The third shows the adapter you need to buy to insert the wire into the testing port. Mine was included with the kit, I forget what it is called.
Oh and here's a pic of the finished product.
