battery cable?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2006, 04:55 PM   #1 (permalink)
wormhole's Avatar
View wormhole's Photo Gallery
4th Generation battery cable??
How hard is it to replace the positive battery cable? The end of mine where it connects to the battery is messed up to the point that I have to move it around until I'm able to start my car. 98 4 cyl.
wormhole is offline   Reply With Quote
Old 06-19-2006, 05:10 PM   #2 (permalink)
View The Car Newbie's Photo Gallery
is the cable really corroded. if it is then u can clean that off with a wire brush
The Car Newbie is offline   Reply With Quote
Old 06-19-2006, 09:46 PM   #3 (permalink)
Engineer, tinkerer
View arlo's Photo Gallery
I just replaced my terminals, which meant I needed to get some more slack in the wire. So do what I did: follow 2 wires (for my gen 3 it had one for the starter, one to the fusebox) and cut off the casing (plastic tubing and electrical tape) in order to gain more slack. I got at least 4 inches this way. Then just cut and strip the wires. If you go this route, you'll need new terminals, so thats 15 bucks for a gold plated one, 25 for both at autozone. good luck!
arlo is offline   Reply With Quote
Old 06-20-2006, 12:15 PM   #4 (permalink)
Del The Funky One
Delay_FTB's Avatar
View Delay_FTB's Photo Gallery
Check the stickies in the AV forum. There's one on extending stock battery wires. Pretty easy actually.
Originally Posted by cam2Xrunner
With a bangin sound system, Carputer with online connection, 1+ lateral G's, and a Twizler Dispenser. That's pimp right there.
Delay_FTB is offline   Reply With Quote
Old 06-20-2006, 04:13 PM   #5 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
X2....imma do mine next month along with replacing all the grounds with 4g wire...
lucanhookup is offline   Reply With Quote
Old 06-21-2006, 12:44 PM   #6 (permalink)
Del The Funky One
Delay_FTB's Avatar
X2
Then I'm gonna do the big three too.
do i disconnect my negative battery cable off when pulling harnesses apart?? Whitecamryghost Camry & Solara Lounge 2 05-18-2006 11:14 PM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
battery cable help wormhole Camry & Solara Lounge 15 09-25-2005 05:23 PM
Replacing battery cable (all of them) in 1997 V6 Camry. kenratboy 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-22-2005 11:23 PM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 03:29 PM
