Will Fuel System cleaner ruin the oil that's in the engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2006, 08:12 PM   #1 (permalink)
'00 Camry V6 (1MZ-FE)
View NewRacer's Photo Gallery
I've heard that the Fuel System cleaner (the one that put in the fuel tank) will ruin the oil that's in the engine. Is there any proof?
NewRacer is offline   Reply With Quote
Old 06-19-2006, 08:17 PM   #2 (permalink)
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
I don't see how, unless you have a really bad intake leak directly into your engine oil to which case your car would be stuffed anyway.
I have used it before without a worry.
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
Old 06-19-2006, 09:08 PM   #3 (permalink)
View marc780's Photo Gallery
Maybe you heard that this happens when a shop does an injector clean. This is where they hook up directly to the injector fuel line and force pressurized solvent through the injectors. When this is done, the cleaner is undiluted by gas. And on top of that, the professional grade cleaner is much stronger than the kind from walamart that we dump in our tank.
The professional grade solvent chemicals are so strong that they can damage the bearings, etc. So yeah, if this is done, they often do recommend an oil change right after because theres a good chance some will make its way into the oil.
But for the regular gum-out type stuff, nope, never seen it ruin an engine.
Old 06-20-2006, 06:23 AM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
It is 'leak down' or cylinder 'blow by' where the piston rings don't seal well, then what you get is the fuel diluting into the crank case. If concentrated solvent is used, then it will end up in the crank case and ruin the oil.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-20-2006, 06:11 PM   #5 (permalink)
But that doesn't happen to healthy engine, correct?
Old 06-20-2006, 10:50 PM   #6 (permalink)
View toyomoho's Photo Gallery
If you are just putting fuel injector cleaner in the tank, you will not have a problem. Follow the directions. If you are worried, put the cleaner in the tank 3-400 miles before you change the oil.
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Can I use Synthetic motor Oil at 5k miles? Meteor_Proof 2nd Generation (2005+) 39 04-07-2006 01:00 PM
Fuel System Cleaner? Beez97Cam Camry & Solara Lounge 53 03-21-2006 05:00 PM
Did I ruin my engine by using too thick of oil? timn29 Yaris, Vitz and Echo Forum 11 12-20-2004 11:19 AM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
