tps or tranny ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2006, 12:50 AM   #1 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
Question tps or tranny ?
well this is been happening to my car for a few months... but lately it's been happening more and more often...
i get these really fast jerks in the car when i'm driving... it usually happens when i'm starting from 0 or merging on the freeway.. it's really fast jerks like the car just bogs down for a second and then it goes again i tried testing my TPS today thinking it's probbly that because it usually happens around 1500rpm but if i'm driving it hard it doesn't really happen but i'm confused about the terms of the test
here's what they told me to test
i discconected it on the car and got an ohm meter and checked the ohms
this is what i'm suppose to get but wtf is continuity ?
i did PSW to E1 i open the throttle then i get some reading near all the way open then i did IDL to E1 my meter just read 1 (which is out of range) the whole way from close to WOT
so i take it my TPS is broken? which would be why i'm having jerks @ lower rpms ? i just want to make sure.. i don't want to spend more useless $$
this is a gen2 BTW 3sfe w/o ETC tranny
Old 06-20-2006, 02:42 AM   #2 (permalink)
View toyomoho's Photo Gallery
Continuity would be 0 ohms.
"Out of range" would be the resistance is too great for the meter to read. Meaning no continuity.
If the TPS were say a light switch. Continuity measured through the wire terminals of the switch would mean the light switch is on. No continuity measured would mean the switch is off (or broken). The ohm reading would be out-of-range or infinite.
Old 06-20-2006, 03:29 AM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Basically, Continuity means "connection". If something has continuity, it will show a numeric reading on the diode test on your multimeter. If there is no continuity, the multimeter will deflect, showing a -1.
That test is saying that at those particular angles, the multimeter should show "a connection" between the specified pins.
I don't like how it states it in degrees...makes it hard to test. My book shows the 2vzfe one being tested with a feeler guage and a .mm gap.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 06-20-2006, 11:17 AM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
ok ok may be i did the test wrong because i was just getting out of range most of the time... i'll try another range later tonight... BUT BUT this morning when i drove to homedepot to buy an air hose... my car did NOT jerk at all not even once !!... may be it was just a lose connection and i fixed...either that or my car heals itself !!!
95 camry auto tranny issues ziddey 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-08-2006 08:32 PM
How to: Change tranny fluid? SmokeyWren 2nd Generation (2000-2004) 4 04-29-2005 11:51 PM
signs of tranny problems bowlofturtle Camry & Solara Lounge 1 04-10-2005 01:02 AM
5f se to 3sGTE ?'s gt r Celica Forum 15 04-09-2004 12:22 AM
tranny time! racerhex Camry & Solara Lounge 30 07-23-2003 12:44 PM
