Originally Posted by JMSinMD
Well with the massive amounts of information you have given us I can tell that you have a 1992-1996 Toyota Camry.
check the inside of your drivers door, it should say there where the vin is. also, you can narrow it down by the back, if its the full red "light" with camry on it:92-94 if its got that body coloured panel with camry ont it :95-96
It's either a DX, LE, XLE or SE.
should say on the trunk, at least if its le or xle
It's either a 2.2 I4, 3.0 V6 1MZ-FE or 3VZ-FE?,
count the number of spark plug wire thingys you have, 4 or 6 will tell you how many cyliders
either a 2 door or 4 door,
count your doors
and either a 5 speed manual or 4 speed automatic.
youll know by how you shift it.
Your interior is either cloth or leather
again, look at it.
and you may or maynot have a moonroof.
look up.
You most likely have an am/fm/cassette but you might also an am/fm/cassette/cd. Hope this helps.
try to stick a cd in.
