oil pan keeps leaking ughhh - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2006, 09:39 AM   #1 (permalink)
Meet My GF...Camry
View NowUCMeNowUDont's Photo Gallery
3rd Generation oil pan keeps leaking ughhh
ive tried everything its hopeless it keeps leaking and gettin on my exhaust piping and turns into a big ass smoke show...last resort is to send it to the dealer or a shop to get it professional sealed or something...neone know how much and how long theyll have my car???
NowUCMeNowUDont is offline   Reply With Quote
Old 06-22-2006, 11:19 AM   #2 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
I don't know what you've attempted to get it to seal but a common problem I've seen is pans which have been over-tightened. This causes the metal to 'flare out' around the bolt holes and you're hard-pressed to ever get it to seal. It's possible to repair it with a block and a smooth-faced hammer. (I would use a body hammer.) Doesn't answer your question but worth checking.
Dave's is offline   Reply With Quote
Old 06-22-2006, 11:41 AM   #3 (permalink)
Meet My GF...Camry
ive used rtv gasket sealant the orange one high heat temp and before i did that i cleaned the surfaces of the old gasket and used a brake and parts cleaner i used new bolt since the old ones were really oily and old...still leaking
Old 06-22-2006, 12:35 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Are you sure that it is the pan that is leaking? Check the oil press. switch and your valve cover for other sources of oil too.
Overtightening forces the FIPGasket out of the joint. I use a grey high modulus (hard) RTV for oil pans.
Start with new RTV on clean surface and assemble ASAP, tighten evenly to 75-80% and let it rest for a bit then tighten again.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-22-2006, 12:44 PM   #5 (permalink)
View ecucio's Photo Gallery
I did my oil pan with felpro gasket! It works good. Dont leak oil anymore. Just make sure to flatten the pan with ballpin hammer and torque it to spec.
ecucio is offline   Reply With Quote
Old 06-22-2006, 01:51 PM   #6 (permalink)
View toyomoho's Photo Gallery
I had a valve cover gasket leaking on the back side of the engine. Very difficult to see and track down.
Old 06-22-2006, 11:03 PM   #7 (permalink)
View mikegett's Photo Gallery
This may be a stupid question, but did you change the oil plug washer? They are not meant to be reused after oil changes.
mikegett is offline   Reply With Quote
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Help oil leaking. skrewdriver88 Camry & Solara Lounge 2 04-15-2006 08:21 AM
leaking oil 2000LEV6 Camry & Solara Lounge 2 04-06-2006 11:57 PM
Oil pan question? White89SR5 Archived Corolla threads 4 10-07-2005 06:14 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
