accessory belt whine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2006, 02:28 PM   #1 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
Hey guys, I searched about this but never found a thread with a resolution... my car hasnt sounded right since it was at toyota last. when I got it back from the timing belt/ water pump replacxement in november it sounded different, a whiring sound coming from the engine bay. I took it back and had them adjust the timing belt, they said it was good to go.
I still noticed it but thought eh, whatever, they said its adjusted... then I took it in in april because of a coolant leak and a belt squeak (accesory/altenator belt). they ended up doing a new radiator blah blah blah and tightened the accessory belt- now it is even louder.
Its starting to really annoy me... the car never sound to sound like this. It is a whiring/whining sound that definately sounds like belt whine- during idle and then increases in rate as i accelerate, slows back down when the car shifts, etc. My accessory belt looks old and worn, i noticed a fray on it as well. do you think this is what would be causing the sound? this is an easy belt to replace i believe, probably isnt too difficult.
thanks for the feedback
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 06-25-2006, 03:36 PM   #2 (permalink)
View toyomoho's Photo Gallery
Try partially removing the accessory belt and see if the noise is still there. Most likely you will will need to remove it from the aternator pulley but not completely off the car. This can also be the alternator bearing.
Old 06-26-2006, 01:51 AM   #3 (permalink)
98 Camry
View dchriste's Photo Gallery
mine whines but its not from the accessory belt.. i have a gen 4 and its the power steering pump belt which is a belt of its own, i dont know if the gen 3 uses a separate belt just for the steering pump as well but u could check it out
dchriste is offline   Reply With Quote
Old 06-26-2006, 02:40 AM   #4 (permalink)
View Ken4's Photo Gallery
Belts dont whine. Rubber on metal never whine. At the most, they squeak. Metal on metal will whine, e.g. timing chain, bearings, etc.
Ken4 is offline   Reply With Quote
Old 06-26-2006, 06:55 AM   #5 (permalink)
93 240sx SR Hatch
DAMON's Avatar
ever heard a supercharger??
Old 06-26-2006, 05:43 PM   #6 (permalink)
00 V6 5speed
hester21289's Avatar
View hester21289's Photo Gallery
My car whines in second gear, but when i shift into third it is not as loud.
2000 Toyota Camry LE V6 5speed(FOR SALE)
K&N|Magnaflow|Alpine|JL Audio|Profile
http://www.cardomain.com/ride/2473219
hester21289 is offline   Reply With Quote
Old 06-26-2006, 05:59 PM   #7 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
If the PS pump the alternator belt ect... slips/gets hard/old they do indeed make a whine noises, also the water pump can make such sounds, so you may want to check that even if it`s new. the alternator itself could also make whine noises when the bearing get worn.
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Old 06-26-2006, 09:18 PM   #8 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Take off the belt as previously stated, if the whine goes away, then youve targeted where the whine is coming from. While you have the belt off spin the alternator and see if you hear anything, you should hear NOTHING. if you hear nothing, than its the belt, if you hear something, time to replace the alternator. Also make sure the belt is tensioned right, a loose belt will whine like you stated and a too tight belt, well will ruin everything . good luck.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 06-26-2006, 10:04 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
i'd say ps pump belt, thats usually the worst. 1. cause more water/dirt gets to it cause its on the bottom. 2. because the PS fluid can be a strain on the pump, therefore a strain on the belt.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 06-27-2006, 01:17 AM   #10 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
and there can be cracks in the belt that can't be seen until you take it off and check really carefully - I remember before I changed my accessory belt, it sounded like I had a supercharger under my hood the whine was so bad, but the belt looked pretty good until it was taken off and there was a crack over a foot long in it
HaHa
Old 06-27-2006, 07:16 AM   #11 (permalink)
93 240sx SR Hatch
DAMON's Avatar
i just had the accessory belt tightened at toyota when it was in for other services because it was loose and squelaing... but i think I could use both that and a power steering belt- they both look old and they arent too expensive, might as well throw them on there. Those are pretty easy belts to replace if Im not mistaken, correct?
Old 06-27-2006, 01:36 PM   #12 (permalink)
TN Pussy Man
yup just make sure you retighten them properly
HaHa
Old 06-27-2006, 01:40 PM   #13 (permalink)
93 240sx SR Hatch
DAMON's Avatar
is there a speical tool needed to measure tension? i think my hanes said something about one but it doesnt seem like you would need anything... Ill just have to have someone else check the tension as well to make sure its okay
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
accessory belt twheeler2020 89-95 Toyota Pickup/Hilux 0 11-15-2005 06:42 PM
Accessory Belt thetailwind MR2 Forum 2 07-11-2005 04:22 PM
non-interference engines?? 90celica General Discussion 13 11-09-2004 10:34 PM
