Is it true that when driving, the battery is not use, mainly alternator is used? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2006, 09:28 PM   #1 (permalink)
'00 Camry V6 (1MZ-FE)
View NewRacer's Photo Gallery
4th Generation Is it true that when driving, the battery is not use, mainly alternator is used?
NewRacer is offline   Reply With Quote
Old 06-22-2006, 09:30 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
yes. Battery is used to start the car, the alternator is used to provide the rest of the electricity for everything else
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 06-22-2006, 09:32 PM   #3 (permalink)
What if the electricity the alternator generated is not enough to keep up with the car's equipment? Will the battery be used then? On my Camry, the engine raraly stay above 2000 rpm, I don't think it's enough to keep up.
Old 06-22-2006, 10:10 PM   #4 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
^you are correct
WhiteRabbit is offline   Reply With Quote
Old 06-22-2006, 10:13 PM   #5 (permalink)
View ieee_raider's Photo Gallery
If that were the case, your battery would constantly be dying.
Your battery is very rarely used when driving. If you're moving the car, you're cranking enough juice to not only run your devices (radio, headlights, etc) but also enough to recharge the battery from what was used to start the car.
2007 Camry XLE V6 - Black / Bisque - Heated Seats, Smart Key, Stability Control
And... My Truck - 2004 F-150 SCab
ieee_raider is offline   Reply With Quote
Old 06-22-2006, 10:26 PM   #6 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
That should not happen as the alternator in your car is design to power everything if your car, including charging your battery. The only time your battery will start to drain is if there is something wrong with your alternator/voltage regulator OR if you added electrical accessories to your car and now it is demanding more current.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 06-22-2006, 10:41 PM   #7 (permalink)
Car Geek
View skywise's Photo Gallery
If there's excessive load and low idle, the battery will drain.
It isn't really a matter of alternator or battery switching jobs, the alternator is hooked up to everything along with the battery. If the alternator is running fast enough to overcome the load of the car at a given moment, it'll charge the battery. Otherwise the battery will drain to maintain the load.
An example of when the battery is propping up the system would be when the engine is idling, the headlights on, the brake lights on, the AC on full, and both engine fans going.
But, any sort of RPM over idle and the alternator will be able to cope and get the battery back to snuff. You can tell this is happening by either listening to the AC fan or watching the headlights. If the speed changes/lights brighten when you step on the gas, then the alternator wasn't holding up it's part of the load.
Normally, a car won't have too much trouble with any of this, there's so much reserve in the battery and the alternator can push so much current. I also ride motorcycles and the alternators in those are puny in comparison. (and the battery tiny as well)
The early model of my bike just had a 28 amp alternator and would need 2000RPM or greater just to charge ok. You'd have to watch how much hot rush hour traffic you were in or you'd be in danger of the battery going flat before you got home.
The upgrade on my bike is a 40 ampper, much nicer and anything over idle is good enough to charge.
Sky
skywise is offline   Reply With Quote
Old 06-22-2006, 11:08 PM   #8 (permalink)
*Place Title Here*
View Go4shoped's Photo Gallery
yes and no.
The battery is used to power everything, yet the alternator is recharging the battery at the same time. get it?
So if the alternator isnt putting out enough juice, the battery has to make up for the loss and then you have a dead battery.
Go4shoped is offline   Reply With Quote
Old 06-22-2006, 11:40 PM   #9 (permalink)
View AmanO's Photo Gallery
So what if I fire the car up and remove the battery?
Or push start a stick camry?
I wonder how much less power my system takes when my lights are on since I have converted everytrhing I can to LED. (or CCFL)
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
Old 06-22-2006, 11:51 PM   #10 (permalink)
*Place Title Here*
it will run but its not advisable especially with an efi car.
Old 06-23-2006, 01:42 AM   #11 (permalink)
View marc780's Photo Gallery
Some people have told me they have sometimes disconnected the battery with the engine running, in order to "Test the alternator". And i told them this is not a good thing to do, because if you try this you risk frying something in the electrical system. And my only question to these folks is, why??? A cheapo multimeter is $10 at Harbor freight or Walmart; and if you can count to 14, you can test your charging system without doing dumb things like removing the battery clamp from a running engine.
And most auto makers specifically advise against doing this especially as there is absolutely no reason to do it, except maybe in emergency.
Old 06-23-2006, 08:22 AM   #12 (permalink)
Francois L'Ollonais
lollonais's Avatar
View lollonais's Photo Gallery
When you ghetto your car with neons, big amps to power 10 subwoofers, 100 watt fog lamps, hydraulics and you plan to tow your jet skis, then you should worry about over working your alternator and killing your battery. First sign of you overworking your alternator, your headlights start dimming.
2007 Black Camry CE
20% Black tints, Prestige Alarm with Solenoid for Trunk
2009 Pearl White Highlander Hybrid Limited
Navigation Package OEM everything except overhead DVD
lollonais is offline   Reply With Quote
Old 06-23-2006, 12:47 PM   #13 (permalink)
Del The Funky One
Delay_FTB's Avatar
View Delay_FTB's Photo Gallery
A little drastic, but the point is well served. I'll be installing two amps (~150 watts and ~800 watts) going to my speakers and subs, and that alone would be enough to suck up all of the alternator's power. Combine that with the starndard usage in the elec. syste (ac, lights, power windows, etc...) and I'm well over my alt's limit, so I need a bigger one (Cam, WTF is up with this HO thing?).
Originally Posted by cam2Xrunner
With a bangin sound system, Carputer with online connection, 1+ lateral G's, and a Twizler Dispenser. That's pimp right there.
Delay_FTB is offline   Reply With Quote
Old 06-23-2006, 01:25 PM   #14 (permalink)
Francois L'Ollonais
lollonais's Avatar
Just get some big capacitors for your set up. That would take some stress from your alternator.
2007 Black Camry CE
Old 06-23-2006, 02:08 PM   #15 (permalink)
Del The Funky One
Delay_FTB's Avatar
No.
Don't do that. It's a band-aid for a weak elec. system. Until you have verified that the alt., batt., and everything else is working properly, don't waste your money on a cap. Even then, you can do the "Big 3" and upgrade your battery-to-ground, alt-to-ground and alt-to-battery connection wires, and will aid in voltage drops that might occur in your electrical system.
Do a search on www.elitecaraudio.com, www.sounddomain.com, our own A/V section forums and wherever else you can think of and you'll find an abundance of knowledge on cars' electrical systems, capacitors, alts., batts., the big three and everything else you can imagine.
Big 3 Grounding Kit - Will it blow out the battery? white3ch0c0late Camry & Solara Lounge 33 03-15-2010 08:17 PM
Battery Relocation/Second Battery cam2Xrunner 2nd Generation (2005+) 18 09-10-2007 07:04 PM
Myth Busters - Driving on a cell phone is potentially as dangerous as driving drunk touringcamry Off Topic 6 06-15-2006 10:16 PM
battery leak eating engine bay... (and weird CD player problem) brownyy Camry & Solara Lounge 17 04-17-2006 11:28 PM
Driving will be so much better if... TRD 4Runner Off Topic 14 11-16-2002 08:09 PM
