Transmission Fluid Question...... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2006, 01:08 PM   #1 (permalink)
View illicitx's Photo Gallery
Hey whats up guys, i got an 03 camry with 72,000 miles on it.
I haven't had to change the transmission fluid until now.
But im confused on which service to get? Transmission Flush or the drain and fill?
Which one should i get?
illicitx is offline   Reply With Quote
Old 06-23-2006, 02:30 PM   #2 (permalink)
View todds21's Photo Gallery
USA
I would flush it. The drain and fill is only going to get a couple quarts out of the pan.
todds21 is offline   Reply With Quote
Old 06-23-2006, 03:58 PM   #3 (permalink)
Sheep in Wolfs Clothing
View 94camryxle's Photo Gallery
I do a drain and refill every 30K miles. But I guess a flush would be good since you already have 72K miles.
94camryxle is offline   Reply With Quote
Old 06-23-2006, 05:17 PM   #4 (permalink)
View ultimate328's Photo Gallery
I would only "service it" meaning drop pan, change fluid, filter and gasket. If it des not have a pan on it then drain it fill it and redrain it. This will save your transmiossion due to the fact that when you "flush" the transmission it might cause havic. The simple reason is there are settlements of clutch material that lives in corners of the transmission. When you flush it that will break up those elements and might get them caught in the valve body or governon springs (governor if you have an older vehiclefor the new ones are all valves and electronics) and cause no upshifts.
Sam
ultimate328 is offline   Reply With Quote
Old 06-24-2006, 01:49 AM   #5 (permalink)
View marc780's Photo Gallery
Either one would probably be ok at this stage IMO, you could just do a couple of fluid changes in a row. One important thing, I use only the fluid Toyota recomends, no subsitutions - on my 2002 V6 they say use only their Toyota TIV fluid. And i believe them, so i got 4 qts of it at the dealer. $4 a qt but you only have to do it every 30k. If you plan to flush i'd get a case, which wouldn't be cheap - but your alternative is to have it done and i'd bet you money that the shop will not be using TIV fluid to flush your trans.
Old 06-24-2006, 07:48 AM   #6 (permalink)
View solidg's Photo Gallery
i do flushes every 60k
solidg is offline   Reply With Quote
Old 06-27-2006, 03:26 PM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I have a 1990 Camry with 348,000. I don't know if the 2003 is similar but when I remove the transmission drain pan plug I only get two quarts that drain out (there are 12 quarts total). I like the idea of flushing all of the oil out but I am concerned about all of the potential problems so I came up with a comprimise. Now, whenever I do an oil change (OK, almost always), I try to drain out the two quarts of ATF and refill. This way (in my mind) I am replacing all of the transmission fluid about every 18,000 to 24,000 miles. Overkill, but what the hey.
Kep
Old 06-27-2006, 04:07 PM   #8 (permalink)
I agree, use only Toyota ATF fluid. I tried using synthetic ATF and shifting got a little jerky and engine began to get slightly louder. I don't know if it was related. Since then I traded in my 1994 for a 2007.
Old 06-29-2006, 05:24 PM   #9 (permalink)
That is the best way of doing it. Drain it every oil change. You will get more than 2 quarts out. More like 4-5 quarts per change. Believe me I do this stuff for a living. The transmission capacity is around 8-10 quarts.
Old 06-29-2006, 08:35 PM   #10 (permalink)
View Ken4's Photo Gallery
Drain & refill is good enuf. Use Toyota Type T-IV. About 1 gallon per drain & refill. No need to drop the pan to clean the screen or magnets. Chances are you will develop leaks if you do. Oil pan threads also very easy to strip if you overtighten. Drain & refill 3 times and you can get 90% fresh fluid in there. Drive around the block after each drain & refill to get a good mix. Toyota Type T-IV costs S$24 per gallon tin here. Or around ~US$15. Cheap!
Ken4 is offline   Reply With Quote
Old 06-29-2006, 09:26 PM   #11 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
My Opinion
I do complete flushes every 30,000 miles. Thats 2-3 years for me so what the heck do I care about spending a bit more than just a drain and fill.
JMSinMD is offline   Reply With Quote
MR2 S/C manual transmission question heritage36 MR2 Forum 6 12-29-2005 08:43 AM
Transmission Fluid Refill vairpack77 1st Generation (1995-1999) 6 11-17-2005 04:38 PM
Transmission Fluid Drain-Fill 95 LE mandyfig 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-15-2005 12:00 PM
Gen 5 Transmission Fluid 1200mk 5th & 6th Generation (2002-2006 & 2007-2011) 10 10-18-2005 07:31 PM
Transmission fluid check cam01speak Camry & Solara Lounge 4 10-11-2005 08:28 AM
