Stripped bolt on stabilizer bar bushing into engine cradle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2006, 04:06 PM   #1 (permalink)
Insert Custom User Title
BigPete's Avatar
View BigPete's Photo Gallery
I'm trying to change my front stab bar, and one of the bolts connecting the bushing into the engine cradle has a rounded head. What can I do to get the bolt out. I need to try to keep from ruining the bolt if possible.
1999 Toyota Camry 1MZ-FE 5spd
BigPete is offline   Reply With Quote
Old 06-23-2006, 04:44 PM   #2 (permalink)
Toyota Hemi
camryfour's Avatar
View camryfour's Photo Gallery
They make special sockets for those.
I would say try to take it out with that, and go to a junk yard and pluck one off another camry. If you can find one.
EDIT: I believe they sell them at Sears. OH BTW, some people have found these to be handy with those "security" lug nuts that you buy with a key.
camryfour is offline   Reply With Quote
Old 06-23-2006, 05:02 PM   #3 (permalink)
BigPete's Avatar
only one problem with that. I dont have enough room to fit a socket with a wrench over the bolt. I've been trying combinations of the 12mm socket with extensions, different driver sizes etc., but I can get the 12mm 1/4" socket over the bolt, but between the body, steering rack, and misc. engine panel, I can't get the wrench into the socket. I've been trying to get the open end of my 12mm wrench on, but I have enough room for about 1/8 of a turn, not enough to break the bolt loose. Basically if you look at your driver side wheel well, this is the bolt on the rear side of the bushing on the stabilizer bar. The other side came off with no prob, but of course there always has to be one.
Do they make like a super shallow socket for a 1/4 driver?
Old 06-23-2006, 06:31 PM   #4 (permalink)
Toyota Hemi
camryfour's Avatar
Have you tried PB Catalyst? Maybe let it soak overnight.
Old 06-23-2006, 10:57 PM   #5 (permalink)
View joandjo's Photo Gallery
There is absolutely no room for the bolt-out. Sears also sells low profile bolt-out. But there is no room for ratchet.
I changed mine about 2 months ago after soaking in penerating oil for good three days.
I used 12 points wrench. I could turn exactly 1/12th of turn. So it took 12 trials to make one full turn. It took me more than 3 hours in total.
As suggested by camryfour, soak in good penerating oil. You can also try torch method.
Good luck
1992 Toyota Camry LE, 3vz-fe, 254K mi, still going strong...
joandjo is offline   Reply With Quote
Old 06-23-2006, 11:35 PM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
sounds like a torch would be your best friend, since there's a reason why it got stripped in the first place....
good luck
HaHa
Old 06-24-2006, 12:08 AM   #7 (permalink)
View Novice_cardude's Photo Gallery
torch, oil, whichever you choose will work, and i'd invest in some gear wrenches to make the actual extraction easier. I don't have them at work but I borrow them from time to time and they're a life saver...
Novice_cardude is offline   Reply With Quote
Old 06-24-2006, 07:55 AM   #8 (permalink)
Gameroom cash: $304355
I would stay away from the torch, if at all possible. The torch will burn up the bushing; then if you can't get the bolt out you are up the creek. You asked about a short socket. Why not go buy a cheap socket in the size you need and grind it down on a bench grinder to the length you feel you need. You might also consider buying a flex drive socket in the size you need. Just a couple of thoughts.
Mike
Old 06-24-2006, 10:57 AM   #9 (permalink)
BigPete's Avatar
Thanks for the help.
Well, even though taking a torch to things is in my nature, I'm gonna pass cause I've got lines (possible fuel) right above the bolt.
That's a good idea about the bench grinder, but I don't have access to a bench grinder.
I ended up soaking the bolt in oil, but only the bushing came loose (go figure.) At 2 a.m., I decided to just pull the bushing cover out of the way to get the bar out.
I spent another few hours trying to get the new bar in, but any time I got the bar positioned, the passenger side endup being on top of the tie rod, not beneath it. I'm trying to decide is I should just mark the tie rod and pull it apart to get the bar through. Another option is that it looks like the steering rack is held by two bolts that I could undo and just lift the rack up and the position the bar, but I kinda think that it may be more work that its worth.
Old 08-19-2006, 03:10 PM   #10 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Lightbulb
One can make what amounts to a very low profile ratchet using the following buildup:
First, get the proper sized socket. I recommend a six-point socket for tough bolts.
Next, get a good set of "Gearwrench" style wrenches. I like the ones with a zero offset angle.
Finally, these two components go together using what is called a "socket cap."
http://www.sears.com/sr/javasr/produ...id=00943303000
I've found this combo to be very handy in a lot of circumstances.
Good luck!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Rear Stabilizer bar link nosnelle Camry & Solara Lounge 1 01-26-2006 11:38 AM
Broken rear stabilizer bar -- what is the best fix? Moufette Cressida Forum 3 08-21-2005 10:37 PM
Replacing Stabilizer bar cushions speedyts49 Celica Forum 3 03-29-2005 06:44 PM
gen3 SE stabilizer bar? 87Camry5Speed 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-07-2004 07:24 AM
Stabilizer Arm Bushing cosmicbutthairs Archived Corolla threads 12 07-09-2003 07:13 PM
