Water Pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2006, 11:38 PM   #1 (permalink)
View Larry du's Photo Gallery
Gen5 Water Pump
I have a 2003 Camry with the 2AZ-FE engine with 30,000 K on it. I had to get water pump changed as it was leaking from seal. I was curious if other Gen. 5 C amry owners have had any water pump leaks?
Larry du is offline   Reply With Quote
Old 06-27-2006, 03:04 AM   #2 (permalink)
View anoiel's Photo Gallery
i got a 30k 05 camry se i4 and i have had no leaks. was it covered under the warrenty?
anoiel is offline   Reply With Quote
Old 06-27-2006, 03:37 AM   #3 (permalink)
Yes it was covered under warranty, what's strange to is the wife's 2004 Corolla with 20,000 K is starting to leak also. Antifreeze weeps from seal on waterpump and gets sprayed from belt to underside of hood.
Old 06-27-2006, 11:27 AM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Are you using toyota antifreeze? Did you put in any additives?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
98' Camry Water Pump repair cost? mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2008 06:11 PM
Echo 2000 check engine light Raistlin Yaris, Vitz and Echo Forum 19 03-26-2007 05:33 PM
leak at water pump, 88 camry Kyle1! 1st & 2nd Generation (1983–1986 & 1987-1991) 3 04-26-2006 04:39 PM
3VZ-FE water pump no gasket??? 94_v6_camry Camry & Solara Lounge 3 11-29-2004 12:05 AM
