LEGAL DISCLAIMER: You do this mod, like any other DIY mod on the net, with the clear understanding that the person who made the DIY is in NO WAY responsible for whatever you screw up with your car. Be safe and be careful! Feel free to ask questions, I'll be more than happy to answer.
Alright, well, I'm just gonna put what I used and did since the original source was Honda-Tech.com and adapted for use by filthy Honda engines
I'll put all the links when I edit this post later
Materials needed:
(Internet item numbers are for HomeDepot.com search box)
1 x Husky 1/4 In. Air Compressor Filter -$11.97 *internet #169654"
2 x Husky 1/4 In. NPTM, Auto Plug, 1/4 In. - $1.25 each *Internet # 169671*
1 x PCV (Yes, Positive Crankcase Vent.) line - $4.24 (my line 11/32 x 20")
4 x Hose Clamps - $2.48
Tools:
Wire Cutters or anything to cut the PCV line to fit
Philips head screwdriver to tighten hose clamps
Needle nose pliers or similar to undo the hose clamps on the stock PCV setup
Patience
1. Remove original PCV hose
2. Screw both 1/4 adapters to either end of the air compressor filter
3. Unscrew the filter's body and remove the plastic piece between the filter element and the body of the filter
4. Measure, carefully, how to your new PCV hose to suit YOUR catch can's position (mine was ghetto and half-assed)
The connection order:
PCV valve ---- PCV line ---- Filter INLET --- Filter OUTLET ---- PCV line --- Intake manifold
Notes from my install
*A nice long PCV line will help because I notice that my line is KINDA bending from the filter body to the manifold because it's too short. For the Gen 3 5SFE, 3.5 to 4ft should be MORE than enough.
*Measure TWICE, cut ONCE
*Make sure you are weary of the direction of the flow on the filter. I originally installed it backwards but LUCKILY didn't drive it before I corrected the mistake. (the flow direction is marked by a arrow pointing the direction of the flow.
*The direction of the arrow should be the same direction the hose follows to your intake manifold.,
*Find a good spot to place the catch can where it's easy to get to so you can empty it
*When cutting PCV line, take into account that the PCV lines should NOT bend. It's better to be safe with extra line then sorry with insufficient PCV hose,
FAQ:
Can I reuse the oil?
NO, don't pour that used oil into your engine again. It's been spit out.. just dump it you cheapskate! LOL!! KIDDING!
Is it gonna add 15 HP to the crank?
Nope, it'll make sure you burn LESS oil which will help your valves be carbon-caked free
Where's the filter located at?
It should be in the air tools section of your nearest home improvement store. Ask for an air compressor filter
Can I get a bigger bottle?
Heck yes Kip, you can. I'll update the item number later.. Too lazy to search RIGHT NOW. I don't know if you can still use the 1/4 adapters though. I think the
Where's that plastic thing you say to take out at?
Unscrew the filter's bottle and then unscrew the little white filter element (Remember, right tighty, lefty loosey) and the little black disc thing will fall right out. Then, just reinstall the filter element and you are done.
Can it blow up from heat/air pressure/synthetic oil?
I'mma say NO but for legal reasons, I make NO GUARANTEES. With that aside, plenty of F22Cs, K20, and K24s use the same setup and even LEGALLY drag with this setup with ZERO problems.
Buy PCV hose?
Yes, PCV hose available at your nearest auto part's store (and Homes Depot, apparently... I didn't find it though). Fuel lines are NOT the same thing. You wouldn't buy airline hose to replace your vaccum line so why cut corners?
Thanks to Honda-Tech, Homes Depot, Advanced Auto Parts, and........ Toyota
Any other questions? I'll gladly answer.
