"Sound like the some extra air coming in from the intake. Check the air filter box if it's snug. My friends rubber housing that connected the air box to the throttle body had a crack and it had the same symptoms as yours."
I think diycamry is correct. When you lifted the lid on the air filter housing, it could have caused the tube going from the air filter housing to the throttle body, to crack. That would explain the symptoms you have. Check that out carefully, expecially underneath where you can't easily see it. Take it off or use a mirror if you have to to see underneath.
Mike
