camry starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2006, 12:09 AM   #1 (permalink)
View camry72's Photo Gallery
Died. fuel pump works. No spark at plugs. Reads code 12. 91 camry 6 cylinder. Help
camry72 is offline   Reply With Quote
Old 06-28-2006, 01:50 AM   #2 (permalink)
View marc780's Photo Gallery
some things to check - maybe a broken timing belt not turning distributor; also check for voltage at distributor. If it has voltage in but not out, then the distributor needs going through. Check for voltage from coils. Also on a car of this age, could even be the ignition switch.
Old 06-28-2006, 01:27 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Check out:
http://www.toyotanation.com/forum/t117799.html
Interesting summary
Kep
1998 Camry starting problem ryane75 3rd & 4th Generation (1992–1996 & 1997–2001) 4 06-12-2006 11:52 AM
Short Circuit Fuse Problem 2005 Camry XLE Phenocain 5th & 6th Generation (2002-2006 & 2007-2011) 5 09-13-2005 09:42 PM
Problem starting 1990 Camry. DPK99 1st & 2nd Generation (1983–1986 & 1987-1991) 4 09-13-2005 03:27 AM
Problem starting my 93 Camry ivj 3rd & 4th Generation (1992–1996 & 1997–2001) 5 09-12-2005 11:49 PM
96 Camry Starting problem b_azadeh 3rd & 4th Generation (1992–1996 & 1997–2001) 10 01-08-2005 12:37 AM
