broken timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2006, 10:20 AM   #1 (permalink)
View camry72's Photo Gallery
broken timing belt
91 camry 6 cylinder. Belt broke. What is the possible engine damage? Should I fix?
Thanks
camry72 is offline   Reply With Quote
Old 06-28-2006, 12:52 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Camrys are non-interference engines. Braking the timing belt should only hurt your pride, not your engine. Put in a new belt and you should be back on the road. While they're in there have them replace any wear items. I will be skeptical, however, and point out that if you didn't do the required maintenance on the timing belt replacement(s) then what else needs to be maintained?? Go to your owner's manual and go through the maintenance schedule and make sure that you're up to date. This may not be anything that you need to do today but certainly in the next couple of months.
Old 06-28-2006, 01:58 PM   #3 (permalink)
View Muddassir's Photo Gallery
Are you really sure Kep that you are saying right? Doesn't it break all the pistons, and order of cam and crank movements? (Mine is 92 camry, and I am thinking of replacing the belt within a month)
Muddassir is offline   Reply With Quote
Old 06-28-2006, 03:07 PM   #4 (permalink)
no
It's called a non interferance engine. I spent all day finding this out. The pistons don't get high enough to hit the valves. But thanks for scaring me and ruining most of my day.
Old 06-28-2006, 11:20 PM   #5 (permalink)
View marc780's Photo Gallery
Broken valves?! GAH@ I had this actually happen to me, on my 1988 Nissan pickup Z24 engine. I was trying to remove the crank pulley bolt, to change the timing chain, with a breaker bar and i made the chain skip time. And i did mash the valves and had to do a valve job for $400. But like Kep said, you in all probability dont have this problem because of the magic- words non-interference engine.
So just put the new belt, and the water pump too if you are going to be keeping this car for a long time. Also the idlers too and maybe the cam seals and crank seal too while everything is apart. I know it sounds a long list but if you are planning to drive it into the ground, maybe it is a good idea.
Old 06-30-2006, 11:43 AM   #6 (permalink)
Kep
Kep's Avatar
Keep track of your milage when you install the new belt and just remember to change it out again in about 60,000 miles. Timing belts don't like oil or water so make sure that the compartment is clean with no leaks.
Kep
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
timing belt broken? wadada Tercel, Paseo, Starlet, and Sera Forum 1 05-30-2006 10:45 PM
Likely damage from broken timing belt? soccerman58 Tercel, Paseo, Starlet, and Sera Forum 1 02-09-2006 11:10 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
