Brake Conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2003, 02:32 AM   #1 (permalink)
UltraslowSolara's Avatar
View UltraslowSolara's Photo Gallery
Brake Conversion
I am planning to do rear brake conversion from drum brake to rear disc brake. and i am planning to some junkyars to huntting parts from v6 gen4 camry, v6 solara, or ES300 (years not too sure). Does anyone can provide me some information about it?
Thanks
Joseph
UltraslowSolara is offline   Reply With Quote
Old 03-16-2003, 08:52 AM   #2 (permalink)
Den
86 Celica Gt driver
View Den's Photo Gallery
how much horse does your car has?
look powerful~
Den is offline   Reply With Quote
Old 03-16-2003, 03:44 PM   #3 (permalink)
have not dyno yet. i am still waiting for Greddy pressor sensor arrive, it had been back order for 3 monthes already
Old 03-19-2003, 02:43 AM   #4 (permalink)
any help for brake conversion??
Old 03-19-2003, 09:32 AM   #5 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
4-cyl Camrys with ABS also have rear discs just for you information.
Here is my quick rundown of the parts you'll need.
- rotors
- calipers
- torque plates
- brake pads (shims??)
- hubs
- hydraulic brake lines
Im pretty sure that converting the rears will also require new hydraulic lines to be routes to the rear brakes. These lines i believe run in a small "corridor" underneath the chassis. You'd need to look into this.
I think that you should check out some How-to sites of people doing drum-to-disc conversions on other Toyota's such as Celicas and Corollas. You might learn a lot that is applicable to your project aswell.
My personal opinion is that the front brakes play a much larger role than the rears, especially in a FWD car, and that once you analyze the cost-benefit factor of this modification, it would be worth more to you to spend your money to upgrade your front brakes.
ratko.org
Ratko is offline   Reply With Quote
