Too Much Brake Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2006, 01:11 PM   #1 (permalink)
View stopher's Photo Gallery
I had overflowed the brake fluid because I was in a rush. Is there any way of extracting the excess brake fluid without having to do anything major?
stopher is offline   Reply With Quote
Old 06-28-2006, 01:43 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
A kitchen baster works great. (Big plastic tube with a squeeze bulb on top) You can find them at dollar stores and add a piece of plastic tubing to the end if you need it.
Kep
Old 06-28-2006, 03:46 PM   #3 (permalink)
Gameroom cash: $304255
Kep's idea is a good one, but you can also do this yourself with just a drinking straw. No, you don't suck the stuff out with your mouth; that may be fatal. Just dip the straw in to the brake master cylinder. Now put your finger over the top end of the straw. Remove the straw and then remove your finger when it is over something to catch the little bit of fluid that will come out. Just repeat the procedure until the fluid is at the proper level. This will be slower than using a turkey baster or some other vacuum device, but it will work and most people have a drinking straw somewhere. Be careful not to get any of the brake fluid on the paint. If you do, wipe it off quickly. Brake fluid is an excellent paint remover.
Mike
Old 06-29-2006, 08:21 PM   #4 (permalink)
View diycamry's Photo Gallery
You can also try a stringe. There pretty cheap at the drug store. Like the post above, you do not want to get the brake fluid on any painted parts.
diycamry is offline   Reply With Quote
Old 06-29-2006, 10:50 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
If you have an old dispenser bottle, ie from liquid soap, you can use that to pump the fluid out. Be sure that it's clean and dry. You want to avoid getting water in the brake fluid.
2007 Camry 2.4L 5M
Old 06-30-2006, 02:03 AM   #6 (permalink)
Ok that's a great idea! This is how everyone learned from others.
Old 06-30-2006, 06:11 PM   #7 (permalink)
thanks guys. used a soap dispenser and cut open a water bottle to empty it into. got rid of that brake light that was always on.
How does brake fluid work? touringcamry General Discussion 7 04-17-2006 08:32 PM
clutch and brake fluid rice Archived Corolla threads 2 12-03-2005 02:47 PM
Brake Fluid in Power Steering Resevior acg Camry & Solara Lounge 4 11-22-2005 05:30 PM
Brake Fluid Problem dna59 Camry & Solara Lounge 2 05-22-2005 10:02 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
