Changing alternator belt to by pass compressor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2006, 04:19 PM   #1 (permalink)
View SammyJ's Photo Gallery
3rd Generation Changing alternator belt to by pass compressor
Hello i have 1993 camry V6 XLE, My car is constantly making metalic noise with out a/c is running. I think its the bearing on the compressor. Also my a/c is not working, so I want to change alternator belt from goin over compressor. I can buy v6 DX model without a/c belt but not sure if i can use that belt with out buying any extra pulley. I tried to find pulley/belt diagram for my car to figure out the length of the cable I may need to by pass compressor. Please tell me if shorter belt gonna work on my car or not?
Thanks.....
Here is my car info............
1993, TOYOTA CAMRY V6 (3VZ-FE) XLE Auto Black 190K
SammyJ is offline   Reply With Quote
Old 06-28-2006, 09:09 PM   #2 (permalink)
View toyomoho's Photo Gallery
If A/C was an option on this car, there should be a belt listed for a non-AC car. Perhaps an auto parts store can check this for you. You will need to see if you have a straight shot from the crankshaft pulley (both sides) to the alternator pulley. Is the A/C pulley in the way?
Take a tape measure and wrap it around where you want the belt to go. If the belt can be installed, it will need to be tightened. Was this done at the A/C or alternator? Use the measurement you get from the tape as the length of belt you need.
Old 07-01-2006, 06:20 PM   #3 (permalink)
View jdm93le's Photo Gallery
3rd Generation
yes you can do it , i had the same problem with the bearing making noise , so i went to autozone and got a belt for a non a/c workeed perfectly fine
jdm93le is offline   Reply With Quote
Old 07-05-2006, 07:11 PM   #4 (permalink)
Thanks jdm93le, unfortunetly i didn't read your reply in time, But i went ahead few days ago and have it changed by local car mechanic. I could have avoid labour charges if i knew this ahead of time. Anyways now there is no noise from my car engine. But I won't have a/c anymore. but I can save some gas money lol.... Anyone who is having problem with compressor and wants to avoid it running go ahead and buy a shorter alternator belt listed as w/o ac alternator belt. if someone needs part no. let me knw...... the belt should cost about $20-30 can, ofcourse 15%tax (ontario, canada) not included lol....
1999 2WD Tacoma Coil Spring Compressor bill70 Hardcore Tech and Competition 2 09-23-2005 03:02 PM
'89 Camry A/C Compressor Not Running 89DLXV6 1st & 2nd Generation (1983–1986 & 1987-1991) 7 08-27-2005 03:09 PM
1994 Camry compressor installation? prwood 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-19-2005 08:05 AM
ct26 compressor question silverstreakin Hardcore Tech and Competition 5 08-02-2005 08:31 AM
