trailer wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2006, 09:55 PM   #1 (permalink)
View RadioFlyer90's Photo Gallery
trailer wiring
Hi there! I am building a small trailer to pull behind my wife's '98 Camry, and I am told that wiring in trailer lights to these newer cars isn't as simple as it was in the old days. Does anyone know where I might be able to find instructions or a wiring diagram? I've also heard that sometimes you have to buy a kit that plugs directly into the car's wiring harness- is that true of the Camry? Thanks!
1990 Toyota Pickup, 2wd, 4-spd, reg. cab (sold!)
1998 Toyota Camry, 4cyl auto
1971 Toyota Hilux, 4cyl, 4spd, 4wd, 4 tires...
RadioFlyer90 is offline   Reply With Quote
Old 06-28-2006, 10:31 PM   #2 (permalink)
View toyomoho's Photo Gallery
Wiring for a Camry is not difficult. A web search on trailer wiring with provide a lot of info. The wiring setups and plugs are standardized. You may want to wire your system to allow usage with other trailers.
I would think with a small trailer you can just tap into the cars wiring system. The Camry has a three-bulb system, turn signals, brake, and taillight. A lot of older cars used a two-bulb system; taillight and combo turn signal/brake light.
I think the Camry wire setup is as follows:
L/H Turn Red/Yellow
R/H Turn Green/Yellow
Stop Green/Red
Tail Green/Orange
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
trailer wiring harness D_Rav RAV4 Forum 0 06-25-2006 08:53 PM
having problems with trailer wiring IntenseGravity 2nd Generation (2005+) 0 09-12-2005 01:17 PM
Trailer Wiring Harness Missing? NH05TACOMA 2nd Generation (2005+) 25 08-25-2005 07:17 PM
