HELP!!! Knocking Noise Coming From Tire?!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2006, 05:47 PM   #1 (permalink)
Frank20's Avatar
View Frank20's Photo Gallery
Gen5 HELP!!! Knocking Noise Coming From Tire?!?!
The other day i was driving and noticed a knocking/thumping noise that sounded sorta like a helicopter coming from my front left tire. At first i thought i needed hubcentric rings for my new wheels i just put on. But then i thought its only coming from one wheel and only when i slightly turn the steering wheel to the left to say change lanes. The steering wheel wasn't shaking with it either it was just noise. And it happens under normal driving conditions not like if i were to hit a bump, just by driving on a smooth road.. I then thought it was a rubbing issue but i checked and its not. What could be making this noise? The strut, the shock...? My dad drove it and said it stopped when he applied the brakes and suggested it might be the rotor? Im clueless! Any info on this prob would be great! I hope its not anything to serious.
CAR IS NOW SOLD
Frank20 is offline   Reply With Quote
Old 06-29-2006, 07:01 PM   #2 (permalink)
View toyomoho's Photo Gallery
Does the thump, thump, thump keep time with your speed? If so, check your tires for damage or something imbedded in the tread, screw, rock or nail. If the tires were just mounted on the rims, take it back to the dealer and have them look at it. Could be a bad tire or rim problem.
Pull of the tire and see if there is anything unusual there. Check the rotor for damage or excess play.
Drive the car in left and right hand circles, see if the knocking appears, and if so when.
Old 06-29-2006, 07:13 PM   #3 (permalink)
Frank20's Avatar
I think the thumping does keep time with my speed so i will check the tire to see if there is anything in the tread. I hope thats all it is and nothing more serious. If it was a strut or shock problem would the thumping be more spaced apart and slower becuase like i said this noise is like a helicopter, fast moving not spaced apart.
CAR IS NOW SOLD
Old 06-29-2006, 09:05 PM   #4 (permalink)
my car hates me
View FireEater's Photo Gallery
happened to me twice before. both times it was a rock in the tread. i wouldn't worry.
FireEater is offline   Reply With Quote
Old 06-29-2006, 09:15 PM   #5 (permalink)
View coquibone14's Photo Gallery
i had a previous car to my camry and it had a 4 lug configuration, i managed to rip two of the lug nuts with the part where it screws to, so everytime i was mantaining speed (not accelerating) it knocked from that tire, id check your lug nuts make sure they are tight
coquibone14 is offline   Reply With Quote
Old 06-29-2006, 11:17 PM   #6 (permalink)
View thoughthard's Photo Gallery
I always hear rocks as more of a clicking sound.
Inspect the tires, inner and outer sidewalls, for damage.
thoughthard is offline   Reply With Quote
Old 06-30-2006, 02:00 AM   #7 (permalink)
Frank20's Avatar
So i think i figured out the problem. After driving it around the block at 3 in the morning about a million times i decided to stick my head out the window while driving and look at the tire. And yea it was whobbling all over the place. Guess that means i gotta tighten those lug nuts before my tire and wheel go flyin off the car. I hope thats the end of the noises!
CAR IS NOW SOLD
Old 06-30-2006, 02:24 PM   #8 (permalink)
Frank20's Avatar
Yea so i got a bit excited and thought i figuered out the problem. I was wrong its still making the stupid noiise and im scared as hell to drive the car. Got an appt on monday to get it looked at and hopefully its nothing to serious the car is only a 2003.
CAR IS NOW SOLD
Old 06-30-2006, 02:58 PM   #9 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
So did you inspect the tire for rocks or nails or (in a situation I once had) a bolt lodged in there? As others suggested, that is usually the culprit. But since you said that it is a knocking noise and not a tapping noise, there could be something more serious wrong.
Do you recall hitting a hard bump in the road before the knocking started? You might have bent the rim and it is rubbing against something as you drive. Check the little black flap thing that goes over the wheel too; the wheel might be scrubbing against it somehow. I had an incident with that (after being careless with my bumper) and it made sort of a helicopter-like sound.
My number 1 guess is that your wheel is rubbing against something.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 07-07-2006, 11:38 AM   #10 (permalink)
Frank20's Avatar
So yeah i figured out the problem. Apparently i had the wrong kind of lug nut on the wheel. They were the right style but were too long and didn't hold the wheel on tightly enough. But listen to this bs now. I took it to a local tire store figuring they could get the lug nuts for me becuase thats what toyota told me to do. They tell me it could cost 140 bucks for lug nuts. Thats rediculous and is it even possible? But they can't even determine the size they should be and they are scared to order a set and have them turn out to be the wrong kind. I'm really annoyed by how this is such a little problem and i haven't been able to drive my car for about 2 weeks becuase of it now.
CAR IS NOW SOLD
Old 07-09-2006, 08:19 AM   #11 (permalink)
View nurtlh's Photo Gallery
I bought lugnuts for my '02 Camry at NAPA, sixteen of them for $27.00. I didn't replace the locking lugnuts.
nurtlh is offline   Reply With Quote
Old 07-09-2006, 08:29 AM   #12 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
I got lug nuts off ebay (those tuner ones for rims) for like $40.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 07-09-2006, 05:37 PM   #13 (permalink)
That is ridiculous.
You could buy a McGard installation kit for half that.
I bought Gorilla lugnuts from Big O tire for $1 each.
Old 07-12-2006, 02:18 PM   #14 (permalink)
Frank20's Avatar
Wow just kill me now! This might be the stupidist problem i've ever encountered and the hardest one to fix. The lug nuts i have are to long for the thread and don't fully tighten the wheel. They can't find a proper size lug nut. Either to long or to short! This sucks really bad
CAR IS NOW SOLD
Old 07-12-2006, 02:49 PM   #15 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $910327
iTrader Score: 59 reviews
That does sucks! seems to me if it were the wrong nuts, all four wheels would be doin it. Maybe the tire has a flat spot on it! Weird!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
98 Corolla, knocking noise jaykirs Archived Corolla threads 5 03-20-2006 06:02 PM
Weird noise. rogonzal 2nd Generation (2005+) 2 03-02-2006 02:17 PM
crackling noise coming from speakers 93' camry Audio, Video, and Security - Tech 9 05-20-2005 03:43 PM
Knocking Noise (Not CV Jt.) jefe Camry & Solara Lounge 3 02-01-2005 07:57 PM
ratling noise coming from passenger seat Newbie General Discussion 1 12-13-2002 10:34 AM
