Clutch Pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2006, 11:49 PM   #1 (permalink)
View downsouthdx's Photo Gallery
2nd Generation Clutch Pedal
Hey guys. If you guys have seen my posts lately u will notice that Im working on getting parts together for my auto to manual trans swap. I need to know if anybody has pictures of the clutch pedal and assembly for the gen 2 camry. I want to compare it so I know if I will be able to use this one or if it is too different. Also, I have a later model JDM 3sfe which SHOULD be an 8 bolt engine so a clutch from a 5sfe should work right? seems easier to find good deals on 5s clutches. Ok guys thanks for the help. Peace.
90' Toyota Camry JDM 3sfe Automatic
downsouthdx is offline   Reply With Quote
Old 07-01-2006, 08:43 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
what are you doing again?
Old 07-02-2006, 04:47 AM   #3 (permalink)
im swapping my transmission. automatic to manual. im replacing my stock box with a transmission from a 1990 celica gts. the celica has a 5sfe in it. i wanted to compare the celica clutch pedal assembly with that of a 5 speed camry. i was also wanting to know if a 5sfe clutch would work on a 3sfe.
Old 07-02-2006, 10:06 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
itll bolt up but get all the other stuff from the camry
Old 07-03-2006, 07:51 AM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 07-03-2006, 03:46 PM   #6 (permalink)
Hey kurt thanks alot bro. i'll probly end up having to buy one. its all good tho.
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
Clutch Questions nofear4189 89-95 Toyota Pickup/Hilux 0 10-02-2005 08:15 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
