Sway bar rear bushings and? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2006, 11:49 AM   #1 (permalink)
97 Camry
View Davee's Photo Gallery
4th Generation Sway bar rear bushings and?
Used the search & see Gen 4 sway bar bushings are a problem my 97 LE had front changed once & maybe due again Rear never changed , Tried the looseness test & I will change them. While there I found the forward bushings for the rear susension mount cross member seem rather loose too . Anyone experienced noise generated by these items ? Looseness (vertical ) appears to be about 1/8 inch. Shocks are solid & no play in sway bar links So hopefully only SB bushings. Not allowed to post pic ??
Davee is offline   Reply With Quote
Old 07-02-2006, 02:23 PM   #2 (permalink)
View toyomoho's Photo Gallery
Search this forum for "posting pictures" to see how to post.
Old 07-03-2006, 11:42 PM   #3 (permalink)
I don't sugarcoat!!
View camrycoupe95's Photo Gallery
Not sure I follow your post exactly.....you are having the dreaded Camry knocking sound?
I had a knocking sound in the rear of my 95 Camry. This weekend I replaced the rear sway bar bushings and the noise is completely gone! The best part is the bushings cost $7.94 and took about 15 minutes per side. Try the SB bushings first. Good luck.
1985 AW11
Past Toyota products --1989 Corolla SR5, 1995 Camry LE Coupe, 2002 MR2 Spyder, 2006 Scion xA
camrycoupe95 is offline   Reply With Quote
Old 07-04-2006, 10:14 AM   #4 (permalink)
Insert Custom User Title
BigPete's Avatar
View BigPete's Photo Gallery
Go look at the sticky for the Gen 4 Repair Manual. There are blown up diagrams in there that will show you what part you need and the part number. If you can get us this information, we can help you out.
1999 Toyota Camry 1MZ-FE 5spd
BigPete is offline   Reply With Quote
Old 07-04-2006, 11:38 AM   #5 (permalink)
97 Camry
4th Generation
The rubber parts I am refering to seem to be part of "Suspension Member Lower Stopper" They are Large rubber washers - The clearance seems to be about 1/8 while whell assy is supported -- too loose?
Old 07-04-2006, 12:59 PM   #6 (permalink)
Gameroom cash: $304255
If you are talking about the bushings in the lateral control arms, the rear one on each side of the car should have some front to back play. The front one should be firm.
You may want to read and follow this current thread where another TN'er is having some rear suspension noises/problems too:
http://www.toyotanation.com/forum/t143385.html
Mike
sway bar bushings and such celica/camry Celica Forum 2 06-19-2008 12:27 AM
1989 Std Camry Sway Bar Options sdhartney 1st & 2nd Generation (1983–1986 & 1987-1991) 17 09-15-2005 08:43 PM
Quick Questions for Rear Sway Bar and I searched. xpeed Camry & Solara Lounge 3 05-17-2005 12:57 AM
AE92 Front Sway Bar Bushings 91corollagts Archived Corolla threads 6 11-17-2004 10:28 PM
rear sway bar bushings tntang Camry & Solara Lounge 5 11-12-2004 10:12 AM
