No, the Gen4 and 5 don't come with any lights on the doors.
I've successfuly installed lights onto my '05 - not very difficult. It works essentially the same way your dome light works (that is, if you don't have the gradual fading dome lights). you just need to find a (+) source (i.e. battery) and you can use the door ajar switch as the ground. The door ajar switch/button on your door is pressed in when you close them and is pushed out out when you open your door again. Each time the switch comes out, it makes contact with the metal part of your car, thus creating a circuit - light comes on. Wire a light to each door, each light can be connected to the respective door ajar switch.
If you need pictures, let me know.
2012 Lexus RX350 Luxury Pkg w/Nav + HUD, ML & PA
2010 Lexus IS250 AWD w/Nav
2007 Lexus ES350 Ultra Luxury w/Nav, ML & PA
2007 Camry XLE V6
2005 Camry XLE V6
