Help !! fast - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2003, 05:21 PM   #1 (permalink)
Bring it !
View WickedGen3's Photo Gallery
Help !! fast
guys i just finished fixing my guages.. one of the wires on the switch came off so i went to take it out and fix it.. but when i put it back in i heard this ding.. you know the ding that warns you when you have ur keys in teh ignition and ur door is open.. we now.. i'm not sure if i blew a fuse or somethign... no sound.. no door light.. no power to radio.. help me.. and also.. when the keys are not in the ignition, i try to open the headlights .. none ! nothing works .. until i put the key inside the igniton.. does anyone know about this ?? what should i do.. where should i check...
92 LE
WickedGen3 is offline   Reply With Quote
Old 03-18-2003, 05:40 PM   #2 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
Sounds like you had some bad luck. Here is what I think you should do, or what I would do if I was in your situation, and I have been heh.
Unhook your negative from your battery.
Take the wire off from wherever you put it.
Look for and replace any blown fuses/fusible links
Leave the wire off.
Beg borrow steal an ohm meter
Take the bus/second car to a shop and get a manual with a schematic for your car's model and year also and ohm meter if you can't borrow one.
Ohm check your gauge wiring to make sure you didn't create any shorts.
Fix gauge wiring
Find out where said wire really goes.
Re-attach wire
Put negative back on battery
Pray to the car ghods and hope you didn't fry anything like your ECU
Take it out for a short drive around the block to make sure everything is OK. Don't go too far.
Good luck that's all I can think of.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 03-18-2003, 05:56 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
If you didn't blow a fuse, you've got bigger problems
Phi is offline   Reply With Quote
