ignition problem?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2006, 11:11 PM   #1 (permalink)
View rice's Photo Gallery
ignition problem??
this is not my car, but a friend of mine, it has an auto 5sfe, and you need to put it in gear 1 in order to start the car, if you put it in regular "park" mode it wont start when you turn the ignition, but when put in gear 1, it starts fine, anyone know whats wrong here? thanks
rice is offline   Reply With Quote
Old 07-03-2006, 11:53 PM   #2 (permalink)
View marc780's Photo Gallery
It's probably your neutral start switch. This switch is mounted on the transmission, and its purpose is to prevent your car from starting while in gear. They are not hard to change nor are they too expensive. If you are strapped for cash sometimes it is even possible to take apart and rig some repair to the switch that will last for a while.
This switch will be mounted on the trans, with wires coming out of it. Chances are it is very near or on the shift linkage, at the trans. Please does anyone have a pic?
Camry Ignition Lock problem Nayak Camry & Solara Lounge 4 03-26-2006 12:30 PM
Help! plz ignition problem luis9519749 Celica Forum 2 01-09-2006 04:28 PM
