EGR System Testing and removal problems
A couple of questions for you guys who have maintained the EGR system in Gen 3 Camry:
1) I noticed that the EGR valve is connected to a long stainless steel pipe next to the intake header. Is this required for removal or is there an easier way without having to strip a lot of parts out?
2) If you look at the service manual for testing a EGR system, they want you to insert a SST tool into two terminal connections. Is the SST tool nothing more than to close the circuit? And what is its purpose in diagnosis?
3) When servicing the EGR system, is it usually recommended to replace all of the units (EGR Vacuum Modulator, EGR Valve) or is it ok to just replace the defective part?
Thanks.
