Get a hammer and hit on it from four different sides to get the drum loose. Don't be afraid to go to town on it.
Once it's loose you can get it off. Becarefull about breathing up the brake dust.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
same thing happened to me on the same side. just knock it off with a hammer. it looks a lot harder than it really is lol. when i first looked at it i freaked out then realized it was no biggie.
If a hammer won't loosen it, it has 2 jackholes.
They are 8 x 1.25mm.
Once you have the drum off, beat out the broke stud through the rear.
There should be a acess hole, so rotate the hub til it's over it.
Once the old one is out, push the new one in, then using several washers and a lug nut, thread it on, and force the stud through.
you can drive perfectly fine on 4 lugs. i'm living in europe this summer (spain) and MOST of the cars here have 4 lugs from the factory. (also most of the cars here are wagons with 1.2L diesel engines, with 17" rims and 165mm treadwith tires)...
Yeah i've replaced countless studs at work because other folks cross-thread the lugs onto them >
It's no biggie, just pound off the brake drum, like has been said, pound out the old stud, which has also been said, and put the new one in. You have to get it as flush with the wheel hub as the others. At work I order 2 lugs, cuz I mess one up putting the stud in. I put a couple wrenches (use them the same as washers) over the new stud, put the lug on, and use an impact to pull the stud through. Washers and a 4-way should work fine, just be prepared to put some weight into it.
