my brake pedal throbs and the car shudders rather hard every time i apply the brakes. Walts checked the pads etc.. when they were installing my suspension. They said it was fine. So what the hell is it. If i brake hard at high speed i will vibrate stuff right off the dash.
What Mike said, shuddering when brakes applied, almost always means warped rotors, with warped drums on rear (if used) a distant second.
If they expect you to pay some more money to fix this problem, it might be better to change the rotors yourself if you can. They are cheap nowadays, $25 each or thereabouts. Sounds to me like the shop just told you the easy answer and did something else. So whether you can trust these folks anymore is doubtful, i should think.
