tranny troubles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2006, 03:51 AM   #1 (permalink)
View 32oz.'s Photo Gallery
tranny troubles
a friend of mine has a 94. its an automatic. and she has been having problems getting it into gear from park. any thoughts? need more info?
1991 4cyl 5speed 20% tint stock as a rock w/203,xxx and counting
32oz. is offline   Reply With Quote
Old 07-06-2006, 10:02 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $261690
View Doctor J's Photo Gallery
Could you please be more specific:
Is the selector handle hard to move;
or
The gear is sellected, but the vechicle does not move?
Doctor J is offline   Reply With Quote
Old 07-06-2006, 08:48 PM   #3 (permalink)
"i cant move the selector handle at all unless i push on that override button"
"and hold that down while i change gears"
thats what she said. does that help?
Old 07-07-2006, 08:42 AM   #4 (permalink)
Doctor J's Avatar
Based on the description, the trouble is in the shift interlock system.
For general description of the system, refer to Autoshop101.com by K.Sullivan, technical articles, file H18, Shift interlock system.
My recommendations:
  • with brake pedal depressed, check continuity between term. 3 and 4 on the stop light switch (refer to the electronic manual posted on the read only section of this forum)
  • while depressing the brake pedal, ign. on, engine not running, listen for interlock solenoid clicking.If it clicks, the plastic interlock lever is stuck.
To repair the system, the center console must be removed. On one of my customers car, 88 Camry, I just removed interlock lever in same situation.
Old 07-07-2006, 09:27 PM   #5 (permalink)
alright. i would flame myself for this, but can ya dumb that down a bit? im simple folk here
Old 07-08-2006, 03:22 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
32oz,
There is a pin/lever that keeps you from starting the car unless it is in park. A solenoid physically puts it into position and if you listen for it you may be able to determine if it is working. When it breaks it can keep you from shifting at all. It is a safety feature. You can disable it (just remember not to start the car while in gear).
Doctor J gave you a reference to autoshop101 that will let you learn more about it. The direct link is:
http://www.autoshop101.com/forms/h18.pdf
That is about as basic as you can get.
Kep
95 camry auto tranny issues ziddey 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-08-2006 08:32 PM
V6 5-speed tranny troubles? kenratboy Camry & Solara Lounge 6 03-04-2006 12:50 AM
How to: Change tranny fluid? SmokeyWren 2nd Generation (2000-2004) 4 04-29-2005 11:51 PM
signs of tranny problems bowlofturtle Camry & Solara Lounge 1 04-10-2005 01:02 AM
tranny time! racerhex Camry & Solara Lounge 30 07-23-2003 12:44 PM
