What Do You Think About This Coolant...??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2006, 10:31 AM   #1 (permalink)
Camryologist
ptycamry's Avatar
View ptycamry's Photo Gallery
4th Generation What Do You Think About This Coolant...???
Sup guys..
I decided to do a coolant flush in my V6 Camry..
I'm going to drain all the coolant and then refill it with 2 liters of this SONAX Coolant Protectant with Antifreeze and the rest with water..
Anyone tried it before..?? Thanks...
ptycamry is offline   Reply With Quote
Old 07-06-2006, 10:38 AM   #2 (permalink)
View keithy's Photo Gallery
just out of curiosity, why did you choose that coolant of everything(toyota red, and other aftermarket brands)?
keithy is offline   Reply With Quote
Old 07-06-2006, 11:08 AM   #3 (permalink)
Camryologist
ptycamry's Avatar
I went to a local performance shop to get my Hella Twin-Tone horn a little while ago and I saw this coolant, I remembered my coolant needed to be changed, so I asked the owner of the shop, and he said that this coolant is awesome, he's used it in many cars with great results, made in Germany...
So I was wondering if anyone heard of it or tried it before and if it would be OK with my car...
Old 07-07-2006, 05:30 AM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
You want a HOAT type coolant and be Silicate Free.
Stick with Toyota Red, and mix yourself. I believe you will need more coolant/antifreeze than 2 Litres.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 07-08-2006, 07:07 PM   #5 (permalink)
View marc780's Photo Gallery
after which you gave your money to him for this marvelous product, that is doubtless better than any other antifreeze known to man. what did you pay?
Old 07-08-2006, 07:27 PM   #6 (permalink)
View southpawz's Photo Gallery
Reminds me of a bottle of Windex
southpawz is offline   Reply With Quote
Old 07-08-2006, 08:02 PM   #7 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
I hope you do all of your own maintenance, because if someone checked your antifreeze (jiffy lube, for example), they'd freak out and call in for backup, thinking you've got a leak in your washer fluid bottle or something...
We used to get some machines in from Germany, and they had clear antifreeze. I kinda freaked out the first time I had to check one in. If I hadn't confirmed that it had like -40 deg. protrection, I would've tried to drain it and put something I'm more familiar with.
I think it was propolyne glycol. I didn't get the chance to confirm that, because I don't speak German, hehe.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 07-08-2006, 10:30 PM   #8 (permalink)
View toyomoho's Photo Gallery
Here are a couple of links on this product. It appears to contain glycol plus a few other chemicals.
http://sonax.datenquelle.org/mediaworld/sx-presse/index-e.php?&treeview=28|123|143|172&treeselected=172
http://www.sonax.de/sonax-e/katalog_...product=505541
Old 07-08-2006, 10:47 PM   #9 (permalink)
Quasi-Evil Monkey
renmike's Avatar
Where do you see its ingredients? I went to the links, but I couldn't find any technical specs.
Old 07-09-2006, 12:49 AM   #10 (permalink)
View Novice_cardude's Photo Gallery
Is that pure coolant or an additive?
I've seen yellow, red, green and clear coolant, but never blue
Novice_cardude is offline   Reply With Quote
Old 07-09-2006, 04:30 PM   #11 (permalink)
Recommended antifreeze in this country is glycol based with silicates added. It can be red, green, or yellow but not a one contains alcohol. Every car manufacturer i know specifically warns against coolants containing any type of alcohol.
Alcohol was used as a coolant back in the 40's and 50's when there was nothing better available. And back then it worked fine for keeping your Panzer tank engine from freezing on the Russian front, but it evaporated fast and needed to be replenished frequently. As soon as ethylene glycol based coolant came out, alcohol coolant pretty much went away.
If you want to use this coolant, i would ask Toyota about it first, because it's possible that alcohol could attack seals and parts in the cooling system.
Old 07-09-2006, 05:22 PM   #12 (permalink)
View Camry005man's Photo Gallery
I prefer Toyota one, but I read it and saw that coolant can be changed if your car reaches 160,000km, sparkplaugs 190,000km.
Camry005man is offline   Reply With Quote
Old 07-09-2006, 05:29 PM   #13 (permalink)
Ops, Sonax coolant DOES NOT contain alcohol! Sorry for the wrong info. I will post the MSDS for this product once I find it again.
Old 07-09-2006, 08:03 PM   #14 (permalink)
Darkside Cut Me!!!
Alcohol is not as benificial (useful ) against corrosion. Silacates are not favourable, they coat the aluminum system with a layer of mineral deposits, which can change the cooling rate through the metal to the anitfreeeze. There is also a problem with silacate deposits breaking free.
Silicates can be used for engines with larger coolant passageways, not recomended in your engine though.
Domestic designed engines use the high silicate coolant to fill in casting porosity and plug leaks.
2004 RX330 Sport
2003 Cam I4 XLE
Old 07-10-2006, 03:25 PM   #15 (permalink)
Here is the MSDS on sonax coolant.
http://sdb.datenquelle.org/cms-theme...f/00051626.pdf
1996 Camry radiator coolant disappearing? RAV4EVR 3rd & 4th Generation (1992–1996 & 1997–2001) 8 06-21-2006 12:13 AM
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 09:03 PM
Toyota Camry Coolant Problem vkbajoria Camry & Solara Lounge 14 03-30-2005 08:28 AM
TB Coolant bypass. CrawlingEye Camry & Solara Lounge 24 09-11-2004 11:03 PM
