Originally Posted by NewRacer
I'm thinking of changing the power steering fluid on my 2000 Camry V6, I'm wondering is it possible to drain it just by using pump from family-sized shampoo? You know, using that pump to drain from the reservior?
Also, how much fluid do I need? I've read the manual, but there is no mention of the amount of the fluid. Does anyone know?
Thanks
I siphon the power steering fluid on vehicles from the reservoir every oil change, and it seems to be adequate enough in keeping the fluid clear. I think this method changes out less than 25% of the total fluid in the power steering system.
As for how much you need, just fill up the reservoir until the min/max lines.
However, if you're referring to a complete DIY PS flush, what I have done is:
- Engine off
- Jack up front wheels, so they are off the ground
- Siphon out fluid in reservoir
- Remove reservoir fluid return hose and connect a long tube from it to a bucket
- Plug up reservoir return hose "nipple"
- Fill res. with new fluid
- Slowly turn steering wheel lock to lock until clear fluid comes of the tube out while constantly checking that fluid in reservoir is topped off.
Takes about 2-3 quarts for the "flush."
