should i get new tires ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2006, 01:12 AM   #1 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
do these look messed up yet ? sorry the picture is huge so you can see the details..
i went to get an alignment and the place told me i should get new tires soon...and that was last year.....and i went again this year and the guy said really soon... in between the threads there's a line running all the way around... and minor cracks around the edges....is it really that bad?
Old 07-08-2006, 08:10 AM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
no, that is fine.
Unless you are born rich and $$ is not an issue.
tires will crack over time. the structure of rubber will change a bit due to the enviroment aka heat and cold.
influence on your handling is minimal or non noticable unless you go drifting
skewe is offline   Reply With Quote
Old 07-08-2006, 11:05 AM   #3 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
long as there are no bubbles, large gashes, major deterioration anywhere, you will be fine.
and as skewe said, ur handling will change only a tad, but i wouldnt do something like autox on em, you wouldnt want the cracks to get too large and potentionally cause a blowout.
nodrogkam is offline   Reply With Quote
Old 07-08-2006, 06:45 PM   #4 (permalink)
View marc780's Photo Gallery
Looks to me like those tires could possibly be good for another 5 or 10,000 miles. when the time comes to change 'em I'd put the two good ones on the back and put the new ones on front and you could possibly get another 5,000 from the back ones. And this might soften the blow to your checking acct.
My Dad used to drive his truck tires until you could see the steel cords! Not something i would do unless i were starving. But then these tires were like 8 or 10 ply tires and not as thin as car tires.
From your pictures, like the other fellows said - they look good for a while.
Old 07-08-2006, 09:00 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Stick a penny in the tread....if u see all of honest abes head then u need new tires.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 07-08-2006, 09:01 PM   #6 (permalink)
Gameroom cash: $926700
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Look as though they are dry rotted to me. If it gets too bad the tire "can" (but not too likely) pop. How many miles have they been on, how long have you had them?
5 Lug Corolla WHAT?
Old 07-08-2006, 11:29 PM   #7 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Look for the TIRE WEAR INDICATOR on your tire. If your treads are flush with the wear indicator, it's time to get new tires. if you don;t know what a wear indicator is read up on it on the net
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 07-09-2006, 12:23 AM   #8 (permalink)
View southpawz's Photo Gallery
You can see the wear indicators in his pic...tread wear doesnt look bad....just the dry rotted looking cracks along the edge of the tire. Just keep an eye on them and you should be fine for awhile or atleast til you can save up for new ones
southpawz is offline   Reply With Quote
Old 07-09-2006, 12:58 AM   #9 (permalink)
Pochacco Owns Me
atobe's Avatar
well i've had them for about 10k miles and they came with my rims (aka used) so i rather not risk blowing a tire on a trip so i went out and got a set of kumho estca spt
and they did look rotten... the pic didn't really show the big crack that ran down in between the threads... oh wells rather be safe than sorry
Old 07-09-2006, 10:27 AM   #10 (permalink)
Mat
View Mat's Photo Gallery
Keep an eye on the cracking round the edges, it looks ok at the moment but heat can cause them to open up more and obviously as they get older the rubber will deteriorate. If the cracking gets worse then I would advise new ones but I shouldn't worry at the moment. A lot of tyre fitters here in the UK are paid commision on every new tyre they sell, so if it's the same in your part of the world they will always try to convince you that you need new ones. Trust me, I used to be one !!!!
Mat is offline   Reply With Quote
Old 07-09-2006, 10:29 AM   #11 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
That is what I have always been taught too....
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Old 07-09-2006, 05:31 PM   #12 (permalink)
View thoughthard's Photo Gallery
I was going to mention that crack between the tread blocks. That I would be questioning.
I don't see a big deal on the cracking on the tread blocks. I had some of that on some previous tires.
thoughthard is offline   Reply With Quote
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
Help with rims and tires!!! rpj1984 Camry & Solara Lounge 0 09-30-2002 11:31 AM
