Not a big noticeable amount, especially in a I4. Maybe a 5-10 hp gain, barely noticeable for $200 CAD, unless you custom do yours for about 60CAD. It'll give you a better sound over a better performance increase.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
the horsepower gain is actually from using a higher flow filter instead of the stock airbox type.
unfortunately too many people attest to the CAI as the reason for HP gain.
you'll also have to change filters more often seeing as how there's a ton more pollutants and road debris down below the bumper line.
If I'm not mistaken, there are no Gen 4 cold air intakes (by brand names). They make CAIs for Gen 3 and 5, but not Gen 4.
I checked AEM and K&N. I already know Injen doesn't make one.
For the Camry in my signature (Gen 4), I got an Injen Short RAM intake. Not as good, but as close as you'll get.
The difference between Short RAM and Cold Air? Cold Airs are further away from the engines and pulls in more cold air (obviously). Short RAMs are closer to the engine. It can't pull as much cold air since it's closer to the engine and the engine generates heat (can't pick up much cold air there).
'97 Toyota Avalon XLS
- Pioneer Premier DEH-P980BT
- Bulldog Security 200B remote start
I dont Know about those intkes for the gen 4 i have a 98 and the options are few the intakes are all about the same and the short rams are a waste of money cuz your just sucking in hot air i was looking @ the stock intake and its small yes but it does lead to a inlet just behind the driver side turn signal so (tec) that is a form of a cold air intake i just threw a air hog on mine and it does run better and the gas km went way up i get about 675 to 750 km on a tank but then again i do have full exspulsion system down pipe to the ass
