Spark Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2006, 12:47 PM   #1 (permalink)
View underpowered's Photo Gallery
4th Generation Spark Plugs
At my next oil change, I will need to replace my spark plugs. I am looking at the Bosch Platiinum 4 spark plugs right now and premium wire sets. What differences in performance can I expect from the ones that are installed in 4th generation Camrys?
Thanks
underpowered is offline   Reply With Quote
Old 07-08-2006, 12:52 PM   #2 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
hey there,
from what ive been reading, bosch plugs are no good for the gen4's they have been shown to cause more problems. I would stick with NGK or Denso. Denso is what toyota uses. If you get Denso Plat/Iridiums you will be fine. I'm not sure if the brand of harnesses will make a difference, so bosch maybe ok to use.
i changed my denso plats with new denso plats and there have been no problems.
nodrogkam is offline   Reply With Quote
Old 07-08-2006, 12:56 PM   #3 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
no noticeable difference really, maybe slightly better mileage, but on your gen4, which i presume is stock, you wont notice a power difference.
johnnyzee is offline   Reply With Quote
Old 07-08-2006, 01:27 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Like others have stated, stick with Denso platinums or NGK.
You can get NGK wires which are direct replacement for OEM wires.
2007 Camry 2.4L 5M
Old 07-08-2006, 03:46 PM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Bosch Platinum 4 spark plugs work great in my sons '99 gen4. Over 90,000 miles!
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 07-09-2006, 12:31 AM   #6 (permalink)
4th Generation
Originally Posted by nodrogkam
hey there,
If you dont mind me asking, but where did you read that bosch plugs are not good for the 4th gen. Not trying to be rude, just asking . What kind of Denso plugs come origannaly with the car, and what are the best Denso plugs that I can buy? What is the difference between the Platinum and Iridiums?
Thanks
Old 07-09-2006, 08:28 AM   #7 (permalink)
View Fever's Photo Gallery
We don't know which engine you're asking about.
If it's the 1MZ the denso plats with the double ground electrodes, stock replacements, are they way to go. I wouldn't mess with any other if you want them to last.
'97 Camry XLE
Fever is offline   Reply With Quote
Old 07-09-2006, 10:04 AM   #8 (permalink)
4th Generation
[quote=Fever]We don't know which engine you're asking about.
If it's the 1MZ the denso plats with the double ground electrodes, stock replacements, are they way to go. I wouldn't mess with any other if you want them to last.[/quote
2001, 4 cyl, auto
How to change spark plugs on 1MZ-FE under 1 hour albertezza Camry & Solara Lounge 25 06-23-2011 08:51 PM
Denso Spark Plugs for 1MZ-FE ptycamry Camry & Solara Lounge 10 01-05-2006 02:26 AM
Iridium Spark Plugs!?!?!!? Matsu-Seo Yaris, Vitz and Echo Forum 6 12-03-2004 09:52 AM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 06:21 PM
