The problem you describe where the gas pedal sticks is easily cured by some throttle body cleaner like touring Camry says. Go to an auto parts store, get a can (less than $5), and you can do this in 5 minutes or less once you're home.
It's a fairly common problem that happens on gen4s as I've cleaned it out a few times myself.
The drive-by-wire problem is different issue on newer cars.
Until not too many years ago, the throttle on most cars were controled by a cable that was connected to your accelerator (gas pedal). On newer cars, to simplify assembly, improve packaging, etc.. and consolidate electronics, the accelearator (gas pedal) no longer has a physical connection to the throttle body in the engine
Drive-by-wire means that you step on the accelerator, which tells the ECU how much the pedal moved. Then the ECU sends a signal to the throttle body, which in turn opens the throttle appropriately.
I finally had a chance to experience this first hand last month. I went to Japan and rented a new Toyota Noah equipped with drive-by-wire. Bascially, there's a slight lag from when you step on the gas until the engine picks up.
I don't like it at all, as the Noah isn't quick off the line as it is and the last thing you need is something else to delay the response.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
