Whenever i turn off the engine, i hear a spark igniting sound immediately after the engine cuts off. Like there are 3-4 sparks discharging. I cannot pin point where is it coming from.
The first thing i'd try, is drive the car into a closed garage, at night, or someplace else thats very dark. And then pop the hood, have someone cut the engine and watch the engine. And look for actual sparks, (likely sources - spark plug connections, plug wires, distributor if equipped). Perhaps one of these components is loose or cracked or otherwise defective.
If you see no sparks, then maybe it is time to pull codes, perhaps it could be some sensor or relay thats been broken but still continues to function.
If all of these come to a dead end, bear in mind that Mike may be right, when an engine cools it will often make some pinging and snapping sounds that sound very close to a spark plug snap. But i'm presuming this isnt the first car you've ever driven and that you'd know the difference.
