powercoating the valve cover? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2006, 03:03 AM   #1 (permalink)
it's been a good ride
iTrader Score: 14 reviews
View camry_ricer's Photo Gallery
4th Generation powercoating the valve cover?
is it possible to paint it? i've seen it on some other cars, and it looks really nice. if so, anyone know a place that does it? I'm in the so-cal area (626). let me know, thanks
camry_ricer is offline   Reply With Quote
Old 07-11-2006, 01:02 PM   #2 (permalink)
View hooRAH's Photo Gallery
When I had to replace the valve cover on my girlfriend's camry, I pulled one at a junkyard that ended up not fitting (its for the Gen3 camrys). Instead of taking it back, I cleaned it up with a wire wheel and sanded it down. I'm planning on paiting it one day and selling it to someone who is interested. Since you have a Gen 4, that doesn't help you much, but it shouldn't be hard to find an extra one and a shop to do it.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 07-11-2006, 04:19 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Gen 3 and 4 share the same 5SFE. The valve cover should be interchangable. (Someone correct me if i'm wrong).
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 07-11-2006, 04:27 PM   #4 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
i dunno about interchangeable
but mine is painted
sand it down, then use the high heat spray paint, primer paint and clear
mines looks great and holds up
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 07-13-2006, 02:22 PM   #5 (permalink)
They're not interchangable. The PCV is in a different location and intereferes with the throttle linkage on the newer 5SFE.
Valve cover gasket replacement White Buffalo Pre-88 Toyota Pickup/Hilux 1 01-02-2006 06:37 PM
PCV valve is screwed up... I helped it.. 4EVERCooL 1st Generation (1995-1999) 3 11-14-2005 07:55 PM
97 4runner valve cover on 95 model? tcma99xtr 4Runner Lounge 2 08-14-2005 02:34 PM
Valve cover question YESCA General Discussion 0 03-29-2005 11:12 AM
