Once in a while, usually when my car has been sitting for a couple hours, i'll go to turn it on and when i turn the key all the way nothing will happen. the car still has power, but the motor doesnt start. there isnt a sparatic clicking noise like if it were the battery or starter problem. has this happened to anyone else? it might be a sensor or something minor i'm hoping
Actually it happened to me last week..2 weeks ago I had a clicking noise when starting but my Optima battery was dead. When it happened last week, where like you said absolutly nothing happens, I just waited a few minutes and tried again and it worked. I was gonna make a thread sooner or later too.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
the other week my camry died at the drive in after sitting through 2 movies, but eventually gained enough juice to start and run fine since then. do I need to get a new battery or charge this one, or does this have nothing to do with the problem?
the clicking is the starter not getting enough juice. WIERD that ur car will eventually start on its own without any more assistance. That doesnt sound right, because the battery would only get weaker on every crank not stronger *miracle battery!*
If your batt is over 5 years just get a new one, but while ur at autozone or kragens etc, have them check ur alternator/battery to see if one or the other is teh cause, or perhaps its something more.
My friend's Accord couldn't get start, towed to dealer and found out that the power leaks with the radio, so when he did not use the car, he had to remove the fuse. Now he got replaced and the problem solved.
The next time this happens, locate the starter and give it a good tap with a small hamer or a wrench. Don't try to break the starter, just tap it. If it now starts, you have idnetified the problem as bad starter contacts inside the solenoid, as has been mentioned above. The do a search for "starter contacts" and read up on the problem and it's repair alternatives.
