Spark plug type. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2006, 07:37 PM   #1 (permalink)
Toyota..Moving Forward-->
djarno's Avatar
View djarno's Photo Gallery
3rd Generation Spark plug type.
I have a '95 Camry V6 and I am about to change the spark plugs on it. However, I am a little confused on the spark plug types out there. I have seen platinum, iridium, and copper spark plugs. Correct me if I've missed a few. What I am looking for in a spark plug is smoothness and performance.
What spark plug type would be best for my 1MZ-FE?
djarno is offline   Reply With Quote
Old 07-10-2006, 10:20 PM   #2 (permalink)
Poman's Avatar
View Poman's Photo Gallery
Use platinum which comes with most cars now; or use iridium if you want to pay alot more money and they are better for modded cars. Didn't know they have copper one???
PomaN
99 Original Solara SLE SC@5lb - Original (yup) TRD suspension and muffler (sold)
06 IS350 Stock (sweet)
Poman is offline   Reply With Quote
Old 07-10-2006, 11:08 PM   #3 (permalink)
View toyomoho's Photo Gallery
Platinum plugs are fine for a stock car and much more economical.
Old 07-11-2006, 12:41 AM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Stick with Denso double platinums. About $6 each at Autozone. NGK plugs are good too.
You can get iridiums if you want, but performance increase is negligible and twice the price.
Copper plugs, just avoid them because they won't last as long as the platinums.
2007 Camry 2.4L 5M
Old 07-11-2006, 10:24 AM   #5 (permalink)
062006
Myehrick09's Avatar
View Myehrick09's Photo Gallery
Get the Bosch Platinum +4 so you don't have to mess w/ the gapping on this plugs
1994 Toyota Camry LE | 2003 Nissan 350z Touring 6M | 2004 Yukon Denali XL
Myehrick09 is offline   Reply With Quote
Old 07-11-2006, 10:49 AM   #6 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i hated the bosch +4
denso dual ground it what came stock (well ngk but denso is cheaper) and works the best, but the later engines came with iridium
also the copper will get murderd in this car, the 95+ is a waist ignition engine where they fire twice per revelution. and why the bosch isnt that great is because of the spark like that one fires core to ground and the other fires ground to the core.
^ and leaving it that way!
Old 07-11-2006, 12:26 PM   #7 (permalink)
I don't sugarcoat!!
View camrycoupe95's Photo Gallery
I've always used NGK on my import engines. That's what's in my 95 Camry now.
1985 AW11
Past Toyota products --1989 Corolla SR5, 1995 Camry LE Coupe, 2002 MR2 Spyder, 2006 Scion xA
camrycoupe95 is offline   Reply With Quote
Old 07-11-2006, 01:04 PM   #8 (permalink)
View hooRAH's Photo Gallery
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 07-11-2006, 02:31 PM   #9 (permalink)
Camry uses a waste spark ignition meaning that two spark plugs will fire at the same time even though only one of the cylinders is on compression stroke. On one of the spark plugs will fire from ground to center and one will fire center to ground. So, effectively, each spark plug will fire twice during each 4 stroke cycle. Because of that, the spark plug's life is effectively halved.
To counter act that, Denso and NGK spark plugs are double platinum and have twin grounds so that the life of the plug is doubled after being halved by the waste spark ignition system.
2007 Camry 2.4L 5M
Spark plug location sparck1 1st Generation (1995-1999) 4 11-23-2005 01:42 AM
NGK Spark plug types - Anyone an expert kenny1773 General Discussion 17 03-21-2005 11:37 PM
gen2 91 camry damaged spark plug wires desertstrm2000 1st & 2nd Generation (1983–1986 & 1987-1991) 5 03-02-2005 02:42 PM
Oil In spark plug shafts Luspher Camry & Solara Lounge 7 06-13-2004 11:55 PM
