Originally Posted by Kep
And if it was water vapor this indicates that the head gasket is starting to leak. If your coolant level is low or you keep having to top it off this is a clue. There are additives that will "fix" small leaks OK. After a point you will need to replace the gasket. This is expensive if you take it in.
Kep
not always true. the by product of combustion is water, thus water coning from the exhaust is normal, as long as its not in excessive amounts. or as long as its not green in color, lol...
