Camry Fuel Pumps.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2006, 04:29 AM   #1 (permalink)
Wannabe Noob
Rasco's Avatar
View Rasco's Photo Gallery
Camry Fuel Pumps..
Would it be possible to use the Fuel Pump from a 96' Camry V6 1MZ-FE...and transfer it to my 92' Camry 4cyl. 5SFE? Im not trying to upgrade or anything. I just need a fuel pump to get it running and it just so happens that my friend is parting out his car. Thanks In Advanced.
Rob
Rasco is offline   Reply With Quote
Old 07-11-2006, 05:04 AM   #2 (permalink)
View marc780's Photo Gallery
I would ask the auto parts guy...if the parts numbers are the same, it will work. If not, i shouldn't think so.
Old 07-11-2006, 06:04 AM   #3 (permalink)
View Muddassir's Photo Gallery
Hey Rasco. I dont know whether that fuel pump would work out for you or not. Would you mind sharing exact thing that you are experiencing in your 92 camry that you need another fuel pump?
I had a neon with fuel pump issues, people always recommended using new fuel pump instead of a used one. There are many companies that make after market fuel pumps.
Muddassir is offline   Reply With Quote
Old 07-11-2006, 01:20 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You would have a chance IF:
1) It fit the same mounting bracket
2) The delivered pressure was identical (I understand that the ECU is pretty finicky about this in order to get the correct air to fuel ratio)
3) The wiring was compatible
5) The plumbing was compatible
With them being this far apart (in years and engine models) I just can't see it being interchangeable.
Kep
Old 07-11-2006, 03:15 PM   #5 (permalink)
Gameroom cash: $304355
When I have a question like this, I go to any on-line auto parts website and check the part numbers for the 2 cars using each individual car's year, and engine size. Like marc780 stated, if the part numbers are the same, the pumps should be the same. You may have to change out the brackets.
Mike
T66 Turbo Camry videos (6 videos) Tony the Tiger Camry & Solara Lounge 74 03-26-2008 06:14 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
