Dropped fuel tank, now no start and no fuel indication on gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2006, 08:58 PM   #1 (permalink)
View mespe's Photo Gallery
Hi all,
Thanks in advance.
I needed to replace a rusted out fuel line on my father-in-laws 1993 camry. Well we cut the exhaust and dropped the tank. When we dropped the tank, it hung by the wires going to the fuel pump and sending unit.
After completing the repair to the fuel line, we put everything back together, but the car won't start, and the fuel gauge shows an empty tank. We put in about 3 gallons of gas, so I would imagine it should have read atleast 1/8 tank.
My questions are:
1) is there a fuel cutoff switch to cut the power to the fuel pump in the event of an accident? If so where is it located?
2) Where do the white /black stripe and blue /black stripe go from the the fuel tank. I woud like to check continuity in those lines, but I have no idea where to look.
The only thing I can think of is that we pulled a couple wires out of the connector when the wires were holding up the tank. ( I didn't see the access to the wiring until AFTER we dropped the tank.
3) aNY OTHER suggestions as far as what can be wrong? We doi not hear the fuel pump when the key is switched on, we didn;t get any voltage on the ble and white wires (I figure those wires are for teh fuel pump as they are bigger then the wires for teh sending unit.
Any helpful comments would be apreciated.
Thanks
Marty
www.benzbonz.biz
mespe is offline   Reply With Quote
Old 07-11-2006, 10:51 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
to get to the wires it's under the rear seats... best to check all the fuses first and see if all the wires/connectors are ok
Old 07-11-2006, 11:28 PM   #3 (permalink)
View toyomoho's Photo Gallery
If your fuel gage is not working the wires to the tank sensor must not be hooked up correctly. I think the fuel gage sensor wires are Yel/Red, Yel/Blue and Blk/Red.
The White/Black and Blue/Black wires go to the fuel pump. You will not get voltage to the pump unless you are cranking the engine or it is running. The fuel pump cut off relay prevents this.
If everything is hooked up OK and still does not work, check the fuses.
Old 07-12-2006, 05:25 AM   #4 (permalink)
Gameroom cash: $304355
"When we dropped the tank, it hung by the wires going to the fuel pump and sending unit."
The problem has to be in those wires. They definitely were not made to support the weight of the tank. They are old and probably rather brittle. You may not have to drop the tank again to access them. There is a cutout for replacing the fuel pump under the rear seat. It should be 4 screws to remove the plate to access the pump and it's wiring. There is a generation 3 manual stickied at the top of this forum. Download it and go to the section on engine electrical. If the wiring information you need is not there, then it should be in the section on body electrical. If all else fails, just splice in some new wires to the connector at the pump and splice them as far foreward as you can and see if the car now runs.
Good luck.
Mike
Old 07-12-2006, 05:44 AM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Yeah id say that since you "hung" the tank from the wires..you've either pulled them from there terminals, or internally broken them. Grab a multimeter and check continutity between both ends of the wires to see if theres any breaks.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 07-12-2006, 08:14 AM   #6 (permalink)
You mention the fuel pump cut off relay, where is this device located?
Old 07-12-2006, 08:20 AM   #7 (permalink)
Right where do the blue/black and white/black wires go from teh connector at teh fuel pump. I mean are they on the passenger side access? or in the engine?
Marty
Old 07-12-2006, 02:17 PM   #8 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You mentioned that the car won't start. Is it turning over and not catching or is it not even turning over?
Kep
Old 07-13-2006, 07:00 PM   #9 (permalink)
Followup - end of thread
It appears thhat toyota put an extra connector about a foot away from the connector that ghoes to the fuel pump. Thaqt connector got unplugged. I was able to determine this through the drqawings on this site.
Thanks site operator also thanks to evetyone that helped.
Marty
Old 07-14-2006, 09:23 AM   #10 (permalink)
Glad the car is repaired and that it was something that simple.
Mike
