Are timing belt and waterpump DIY replaceable? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2006, 08:09 AM   #1 (permalink)
View Muddassir's Photo Gallery
3rd Generation Are timing belt and waterpump DIY replaceable?
Hi, I think my waterpump is gone, as it flushes coolent at random times and flush alot. I want to know if someone of you have replaced it yourself? what kind of precautions are neccessory?
Muddassir is offline   Reply With Quote
Old 07-13-2006, 08:36 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Which engine? 5S-FE, 3VZ-FE, 1MZ-FE?
Gen 3 repair manual:
http://toyotanation.com/forum/t62501.html
Timing belt, gen 4, 5S-FE:
http://toyotanation.com/forum/t109966.html
The waterpump pretty much bolts on/off. Its all the other stuff that needs to be removed/reinstalled that may cause problems.
Make sure you understand how to align the crank + cam and install the timing belt.
"Skoolin' the unlearned!"
Goiing to change timing belt... is the dealer telling me lies? poorguy Camry & Solara Lounge 32 09-23-2006 10:29 AM
Timing Belt Tension Trick For 5S-FE Digger1 Camry & Solara Lounge 8 01-06-2006 09:15 AM
just changed the water pump and timing belt on my friends 92, now car idles funny... SILVERROLLA MR2 Forum 6 08-09-2004 09:20 AM
need advice on replacing timing belt & water pump D0UG Camry & Solara Lounge 18 05-06-2004 09:03 PM
98 Camry Timing Belt Pictures Crusader7 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-26-2003 06:24 PM
