coolant temperature switch question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2006, 01:11 AM   #1 (permalink)
View gsjxj's Photo Gallery
3rd Generation coolant temperature switch question
I need to change a bad coolant temperature switch (radiator fan switch) located at the bottom of the radiator on my 94 toyota camry. Do I need to first drain the coolant in order to replace this switch? Thanks for the help!
gsjxj is offline   Reply With Quote
Old 07-15-2006, 05:50 AM   #2 (permalink)
View marc780's Photo Gallery
Nah! Its an easy one. Put drain pan under sensor. Unhook the electrical leads to somewhere they'll be dry. Unscrew the sensor in question, screw the new one in your wet hands. (BTW did i say put some anti seize on the threads first? he he.) Screw new one in. Tigthen moderately, less is more, if it leaks later you can tighten it a 1/4 turn. Replace connector. Pour in some water coolant into the radiator to the amount you feel fell out. Done deal.
Old 07-15-2006, 07:33 AM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
some will leak out as stated above. however, if you are near changing your coolant anyhow, drain it. if not, just do the ol' switcheroo
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
How Make The Dummy Switches Work For Real - And Cheap Too... Hughes500Pilot 2nd Generation (2005+) 7 02-03-2006 10:42 PM
Coolant question Nuke209 Camry & Solara Lounge 11 12-21-2005 10:31 AM
Camry cooling system question rayprog Camry & Solara Lounge 8 12-05-2005 03:43 PM
question about car temperature... lazyedwin Archived Corolla threads 14 12-22-2002 02:42 PM
