starter problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2006, 02:34 PM   #1 (permalink)
View smkdwnn's Photo Gallery
2nd Generation starter problems
installed a new starter today but car will not start it just goes click click click.
smkdwnn is offline   Reply With Quote
Old 07-15-2006, 04:12 PM   #2 (permalink)
View thoughthard's Photo Gallery
Contact Tercel GTS about your problem. He is a starter guru.
Kinda odd the new one does what a worn out one would.
thoughthard is offline   Reply With Quote
Old 07-15-2006, 04:19 PM   #3 (permalink)
Gameroom cash: $304355
If you are hearing just 1 click each time you turn the key, the problem is still within the starter solenoid contacts. I have seen "rebuilt" parts fail right out of the box. If you are hearing multiple clicks when you try to start the car, the problem is a weak battery for whatever reason (bad battery, bad alernator or a loose alternator belt), or loose or corroded cable connections at the battery or at the starter itself.
Mike
Old 07-15-2006, 04:33 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Clicking once when you turn the key usually means bad contacts in the starter. Was this a "new" starter or one from a junk yard? If it's a used one then change out the contacts. There are several good forum posts on this with excellent instructions and pictures. If this is a new starter from Toyota you may want to take it back for a good one.
Repeated clicks when you turn the key once (I beleive) means low power. Make sure your battery is good. Try another.
If you tap on the starter (lightly with a ratchet handle or hammer handle) and it works that is another indication that the main contacts are failing. If this works you may be able to do this off and on for several months before it doesn't work at all.
Kep
Kep
Old 07-15-2006, 05:27 PM   #5 (permalink)
2nd Generation
actually this was a rebuilt oem starter from the local auto electric shop , it just goes click click click.
should have bought a rebuilt starter from from toyota parts.
Old 07-15-2006, 08:56 PM   #6 (permalink)
View toyomoho's Photo Gallery
Check you battery voltage: 12.6 is 100%, 12.2 50%, 11.9 dead. Could be bad battery cables or connections. Check at the battery terminals, starter and ground.
As previously posted it is possible to get a rebuilt starter that has a problem.
Old 07-15-2006, 11:38 PM   #7 (permalink)
it works now. im not sure why though. well i noticed that my #80 fuse on my red battery cable blew. It's for the alternator. I still have that blown fuse in my car i just connected the two pieces. I'm not sure if that #80 fuse can be removed its not easy to get out.
Old 07-16-2006, 12:26 AM   #8 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
cause that fuse is screwed into the fuse box take a look underneath
Need Advice On Replacement Starter jerryjg123 89-95 Toyota Pickup/Hilux 4 06-26-2006 03:47 PM
Starter Stuck Starting d0rkiishchris Camry & Solara Lounge 4 02-19-2006 12:18 PM
Starter Problems 92 Camry 4cyl KILLACAMNY 3rd & 4th Generation (1992–1996 & 1997–2001) 9 01-31-2005 01:19 AM
remote starter install problems koss78a Archived Corolla threads 1 11-19-2004 09:28 PM
Ignition or starter problems spills1969 Hardcore Tech and Competition 2 01-18-2003 11:02 AM
