small electrical things. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2006, 03:06 PM   #1 (permalink)
View hellomota's Photo Gallery
one of my 97's camry back lights wouldn't light up and shows me warning on the dash, what should I check for, is there a fuse for lights? Also my dashboard stoped lightning up, when I turn my headlights on, what is the fuse for the panel as well? Thanks for all the help in advance.
hellomota is offline   Reply With Quote
Old 07-15-2006, 03:35 PM   #2 (permalink)
View Tarzan's Photo Gallery
The warning light means you have a burnt bulb in your tail lights. As for your dash, most likely a burnt fuse. I don't know the location of it since I have a Gen3. Look in your manual.
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 07-15-2006, 03:41 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Try swapping out the left side for the right side on the tail light problem. Make sure that you're changing the "same" socket. If the problem moves from one side to the other then the bulb is the culprit. If the problem stays at the same socket then the socket is the problem. Look for corrosion and/ or loose connections. A fuse is possible but they typically will affect several bulbs, not just one.
The dashboard is a puzzler. My first inclination is to make sure that your dimmer knob is turned up. If you want to mess with it, pull the knob out and bridge the two wires. This will be like having the knob set to bright. If that works then the dimmer switch is bad. If you're saying that the dashboard lights up initially (like when you have your parking lights on) and then shuts off when the headlights come on then I have no clue.
Kep
Old 07-16-2006, 09:24 AM   #4 (permalink)
thanks for the help, no dash doesn't light at all, not when parked, not with headlights. So the question stands does anybody know what fuse controls the dash? Thanks
Old 07-16-2006, 12:13 PM   #5 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
I don't have a '97 but if there's a flip-out 'tray' below and to the left of the steering wheel, try pulling it out to access the fuses. Or it may be behind the kick panel.
Dave's is offline   Reply With Quote
Electrical Drain Issue JetspeedCamry Camry & Solara Lounge 18 10-04-2005 05:06 PM
I hearing things bisondelta Archived Corolla threads 2 09-27-2005 05:07 PM
